Question about Panasonic NN-T990SA Microwave Oven
Microwave runs for about 5 seconds then shut off.
I have a Panosonic 1300 w microwave about 4 years old. It's a(F00064W70AP)) Type AP103. It'll start and run for about 5 seconds and just shut off. Anything I can do?
MicrowaveSvc
  • 9098 Answers
SOURCE: My three second microwave
This is probably due to a defective or possibly loose magnetron.
If yours has loose mounting nuts / bolts or the wire mesh RF gasket was not installed or got pinched, that can also cause
this RF leakage interference inside the oven.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
If you or a friend decide to look into it, we have critical information on safety and disassemblyat our site,
linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 05, 2007
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
SOURCE: panosonic nn-t790 microwave
I pulled the top and sides (one piece) of the microwave. Near where the 110 volt line goes into the unit is a standard fuse ( 18 amp). I used an ohmeter on ther fuse and determined that it was not working and replaced it. Problem solved - unless it blows again.
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Posted on Nov 08, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Microwave won't heat anything
Yeah, it's time to invest in a new oven. The magnetron tube in yours most likely just finally wore out. It's the source of the microwaves, and like any tube it gets weaker with age and finally just quits altogether. It would cost more for a new magnetron than it would for a new oven these days.
Posted on May 16, 2009
Panosonic microwave shuts off after 3 seconds
That is an error saying you have a bad HV Inverter.
Apr 27, 2012 | Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Jan 21, 2009 | Panasonic NN-P294SF Microwave Oven
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Model # NN-T793/T993
My first guess would be to checvk the venealation fan
Mar 31, 2008 | Panasonic NN-T993SF Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
228 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
