Question about Toshiba W522 VHS VCR
Tochiba vc-522 timer recording
Does not come on when timer is set. how to fix this. any ideas?
You may already know this, but you must push the timer button and the one on it's left, marked in red at the same time to set, and then the timer light comes on. and the unit shuts off. I just bought one with no manual, so I'm working my way through it.
Posted on May 13, 2009
It depends what you are recording from. Most newer tv broadcast will block the recording by injecting copyright code into the stream. It forces you to get a dvr system from the company like cable or satellite. Because of the new digital broadcast it makes over the air recording to vhs difficult. More for the fact that you have to hook a converter box to the vcr to get the signal from digital to analog again. Here is the link to the manual.
Sep 23, 2015 | Sharp VC-A582U VCR
VCR Recorder VC-H982 Can't time record. can't select a channel other then 3, 40 av under timer. What is pdc?. where dose it appear. what is sap in set up window? what is air in the channel...
You will probably find a free manual at the Sharp website. That should answer most of your problems. However can tell you that PDC stands for Programme Delivery Control. With it on, say you want to record a program that starts at 9pm and finishes at 10pm. Then all you need is set the control to on, when you set the timer recording, and the video will record your show, even if it starts at say 9.10 and runs while 10.10. The VCR will wait till 9.10 to start and stop at 10.10. Good if a sporting event or live event overruns!
However PDC doesn't work on digital and will not work sometimes at all or if you set the timer wrong. It uses the old teletext signal, which is why if you are in an area that has gone over to digital it should be set to off! As it will never get a PDC signal!!!!
Jun 04, 2011 | Sharp VC-H982U VHS VCR
My vcr wont record when programed but will if you just push the record button
When you set the timer see if PDC appears. If it does switch it to off and try setting a record. PDC sometimes doesn't work. And the recorder will sit there waiting for the signal to tell it when to start recording. Which never comes! However you will have to set the time to adjust for it not recording late running TV shows. For example a show to start at 8pm and finish at 8.30pm, will need to be set at 7.59 till 8.35pm. Or you could miss the start or end! Wheras PDC would get it all even if it started at 8.05!
Nov 22, 2010 | Sharp VC-H982U VHS VCR
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
Would like to tape from tv.
this should help jar your memory some....if your vcr is set/tuned to ch 3...and tv is set to ch 3....cable/dish box is your ch selector (tune to any ch u wish) put a blank tape in press record if you want to record....(you are not home, you must set the timer on the vcr /menu/timer recording settings)...make sure the cable box is set to the ch you wish to record...or else you will miss your recording you want.
Jul 10, 2010 | Sharp VC-A582U VCR
Set the timer to record
Do you have the remote which came with it? Most VCRs of the last 10 years require the remote to setup a timed record, or for that matter, most of the advanced functions- beyond play/rewind/ffwd, etc.
Assuming you do have the remote, and the correct time is set, and the timed record properly setup, some VCRs require a the On-Timed-Record button to be pushed. This sets the VCR in a wait mode, until the time set for the recording to begin.
Consult your owners manual- an online manual may be available if the printed one is missing.
Mar 04, 2009 | Sharp VC-H812U VCR
I have trouble taping when i put the timer on it does't tape.
You are looking for a user manual? Is the Sharp VC-A554U VHS VCR the correct model or do you have another device?
Thank you.
Jan 26, 2009 | Sharp VC-A554U VHS VCR
Lost remote on toshiba w528
You can select those to record with out the remote by setting the record timer to record. For example, if you want to record from one of those input channels on Friday 1 January 2009 at 9:00 to 11:00, it will allow you to choose that as an input channel in that program menu. If not, you will want to buy a replacement remote. VC-522 is no longer available, but VC-617 and other models are.
Nov 16, 2008 | Toshiba W522 VHS VCR
Toshiba vc-522 go web site dl manel shows u codes toward back pages k
Oct 07, 2008 | Toshiba W522 VHS VCR
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
Toshiba W522 VHS VCR Logo
259 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
