Question about EliteGroup K7SOM Motherboard
DOES K7SOM MOTHERBOARD UPGRADABLE? - EliteGroup K7SOM Motherboard
  • EliteGroup Master
  • 3,606 Answers
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=79#Download-2
And the + versions:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=K7SOM+
I would say no because the cpu does not exist anymore.
The only thing you can upgrade is the harddrive and the ram module.
The mainboard uses SDram and DDR ram in there own seperate block.
Sdram is hard to find and expensive.
DDRram can still be bought.
The specifications:
PROCESSORS
462 pin Socket A supports the AMD K7 processors
Full series of Athlon XP/Athlon/Duron processors
CHIPSET
SiS 740 & SiS 961/962 Chipset
SiS 740 Host/Memory controller with high quality 3D graphic accelerator
SiS 961/961B/962 MuTIOL Media I/O
Integrated USB 2.0 host controller in SiS 962
LPC I/O -ITE8705F
LAN: MAC integrated in SiS 961/961B/962 and PHY on board
AC97 Audio Codec: Compliant with AC97 2.2 specification
SYSTEM BIOS
AMI 2MB Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB (DDR SDRAM or SDRAM)
I/O INTERFACE
Hope this was helpfull
Posted on Nov 29, 2012
HOW I CAN FIND VGA DRIVER FOR MOTHER BOARD K7OSM+
There are more than one version of this motherboard. The following link will take you to a listing of all the K7SOM+ versions (plus other older motherboards from EliteGroup).
http://www.ecs.com.tw/ECSWebSite/Product/ProductArchive.aspx?CategoryID=1&MenuID=24&LanID=0#Archives
Jan 13, 2011 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
I want cpu model
the site below should be able to help with what cpu processor you can use
http://www.motherboard.cz/mb/ecs/K7SOM.htm
Mar 26, 2010 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
What cpu can I upgrade to using my K7SOM+ motherboard? curently using AMD Athlon 1800.
Provided below is a list of all supported CPUs for you're motherboard from ECS; http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=316&MenuID=69&LanID=0
The highest CPU is:
AMD Athlon XP 2600+ (.13u) (256K,266,Socket 462)
Cheers'
Mike
Jan 30, 2010 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
WHAT IS THE MAX RAM FOR K7SOM + V7.5C MOTHERBOARD?
Each memory slot can hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 20, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
No Power to Motherboard...
Here are some steps.
Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
Check the cpu power switch if it is correctly attached to the motherboard.
Oct 26, 2008 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
EliteGroup K7SOM Motherboard Logo
213 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
