Question about Vivitar V3800N Zoom 35mm SLR Camera
Idk how to open the back to put my film in i have a vivitarv3800n
Igot a cam 4 photo1 in highschool and idk to do it help
  • John Buettner May 11, 2010
    pattersontes,
    need to know what kind of camera ( slr, point and shoot ) and the name of the camera.
  • 53 Answers
If it is the camera posted in the picture, try pulling up the tab on the film winder on the left side on top, after the tab is out pull the whole dial up and the door should pop open.
Posted on Jan 16, 2009
What AP classes should i take for the medical field?
AP classes are very specific to your college of choice. Unfortunately most AP courses do not transfer well. Your best bet is to contact your college of choice and see which courses they advise, and what will transfer. The last think you need is to take a course that will not help you.
Jan 04, 2017 | Higher Education (University)
I have recently just took a roll of film out of my camera. It is a Asahi pentax K1000. I opened up the back panel to take out my film and the panel closed without any new film being put in. Now the rewind...
Try holding the camera upside down to see if it slides back into place. If that doesn't work, imagine that there is a film in there and wind it back like you would to take the film out, this may put the shaft back into place? Good luck.
Jun 24, 2014 | Photography
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
May 03, 2014 | Minolta Vectis S-1 35mm SLR Camera
My 1995 dr350se just wont run ... i have spark i have gas idk whats goin on can anyone help
Beings as the "valve cover" has the upper cam journals cast into them, did you retorque it properly, and to the correct specs?
Did you tamper with the rocker arm adjustments?
Did you remove the cam gear from the cam shaft? If so, did you reposition it correctly (didn't turn it one bolt hole?)
Jan 07, 2014 | Motorcycles
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
How do you open the back of a minotla gx-a film cam
On the left of the camera is where you power it on, and wind the film. pick up on the silver part of the film winding mechanism. That should pop opent the back. Hope this helps!
Apr 01, 2011 | Minolta XG-A 35mm SLR Camera
My cam was working fine. The film got over and I decided to load a new one. Once I did that and switched on my cam. The cam displays an error sign...??
The film may not be feeding to the take up spool properly. If that is so, there should be flashing symbol something like this: O_ _ _ _ . If that is the error you are seeig , open the back and re-insert your film. You may lose a couple of frames.
Oct 17, 2009 | Nikon F75 35mm SLR Camera
How to you open the door to the film
Usually you lift the film roll winding cam so that the back of the camera opens. Be sure that you have wound back the film to avoid spoiling the film.
Aug 16, 2009 | Kalimar K-90 35mm 35mm Point and Shoot...
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
Vivitar V3800N Zoom 35mm SLR Camera Logo
120 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
