Question about Hotpoint Kitchen Ranges
I have a Kenmore elite 7942 gas range and the keys to program the oven has locked and only reads F7, how can i reprogram it?
I can't use the oven or any of the other settings that the oven provides.I can't even do something as simple like setting the time on it. The screen only reads F7.
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
SOURCE: oven door won't unlock
I had this same issue and consulted the owner's manual. Once on self clean it takes up to 3-4 hours for it to automatically unlock. It is a built in safety feature of the oven.
Posted on Feb 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Posted on Jul 22, 2009
SOURCE: Kenmore electric Range 2005
we are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
Posted on Nov 26, 2009
SOURCE: Kenmore range oven will not hold temperature
You're glow bar ignitor is on its way out. I had this exact problem and swapped mine out with its identical sibling that runs the broiler element. Problem fixed.
Posted on Dec 29, 2009
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
F7 ALARM EXPLAIN CAUSES FOR KENMORE ELITE DOUBLE WALL OVEN ELECTRIC
Hi
Thanks for using FixYa. Error F7 on your Kenmore means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | Kenmore 49233 Electric Double Oven
I have a kenmore elite electric range and it is diplaying a F7 code what can I do to fix it.
f7 error code usually means stuck function switch on control panel. Need to check each button or switch to see which one is stuck
Mar 19, 2010 | Kenmore Ovens
Ge gas range code f7
Hi. This is a Shorted key panel membrane switch. This will require you to replace the oven control board in this case.(F-7)
Oct 01, 2009 | Dryers
Kenwood elite glass top range shows error code F7 for all burners.
F7 indicates a stuck touch pad key. Try pressing all teh buttons on the key pad to see if one is stuck. If you don't have a stuck key, there may be a problem with the key pad module itself
Mar 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
Kenmore elite range oven problems
hi. thanks for the question . i would replace the igniter in oven .thanks the appliance doc
Sep 26, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
F7 alarm
I believe "F7" is a function key error with the Electronic Range Control (ERC). The ERC is not serviceable, so it will have to be replaced. If you can provide me with the model number off the range (usually located on a label inside the lower drawer), I can provide you with a part number. I hope this helps.
Aug 07, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
