Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
My Mitsubishi TV WS-55909 only has 1 HD component imput spot; I want to be able to hook up a Motorola DCH2300 HD cable box and a Sony HD/3D BDP-BX59 DVD player without the hassel of unplugging each device and switching over each time I switch devices. The TV also has a digital TV cable conection but I believe it will not have the 1080 ability and it deffinatly would have to have some type of converter. Any Ideas?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Look on the internet for a hub like usb ones the computers use.
Posted on Dec 22, 2012
  • 301 Answers
SOURCE: Mitsubishi WS-65711 green tint only with DVD via Component
there should be a setting in the menu that you need to make sure is set to YpPbPr not RGB if set to RGB it will give you a green pic on the DTV Input.
Posted on Feb 22, 2008
tlm931
  • 273 Answers
SOURCE: My Toshiba 55" TheaterviewHD works
it sounds like a convergence problem and there are different settings for 720 and 1080 in the service registers
Posted on Jan 16, 2009
  • 14 Answers
SOURCE: BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Posted on Feb 06, 2009
  • 73 Answers
SOURCE: Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Posted on Dec 01, 2009
  • 8457 Answers
SOURCE: Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Posted on Jan 15, 2010
I have a Mitsubishi WS-65513 65 in. rear projection HDTV. I recently hooked up a DVD player to the Component 2 cable inputs but I cannot find the Component 2 selection on the 'Device menu' to tell the TV...
If one or more of the inputs is "missing" or not there you may need to do a hard reset of the TV with the original remote.
If you want to try this confirm the actual model number and I will tell you how to do it.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65513 65" Rear Projection...
I have a projection TV model ws-55909 that will not turn on. The timer light blinks for ten seconds and then shuts off?
the problem on ur tv could 2 problems , if the keep blink all the time is the digital box the problem to fix the digital box u have to replace 7 capacitor on the power supply inside of this box , now when u press power and the blink on then goes off the ploblem is going to bo the convergence ic pl;s 2 pico fuses part #stk392-570
Dec 02, 2010 | Mitsubishi WS-55909 55" Rear Projection...
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
The tv will not turn on. mitsubishi ws-55909
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point, is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Setting 1080i
Component inputs 1 and 2 will only pass up to 480p. to get 1080i you must use the DTV component input.
Dec 07, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Ws-55511 component inputs will not work
you have to hook up the HDTV receiver to the INP (or what ever the initials are) input to get HD
Oct 18, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws 55909
Have you tried pressing in the menu and input/device buttons both in together on the front of the set and hold them both in together for 5 seconds to see if the set will blink a two digit error code? Try that and then let me know if it blinked a code. Please reply to this same post when replying. Thanks
Aug 04, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Color sag on mitsubishi ws-55909 projection tv
Adjust convergents for blue.This is done with your remote control. go into menu, setup, instructions will come up on screen, also in manual.
Feb 04, 2007 | Mitsubishi WS-55909 55" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
