Question about Iomega 500GB Prestige USB 2.0 Portable Compact Edition Hard Drive
When I connect my iomega external hdd to laptop it throws a message "you need to format disk before you can use it" I was getting this msg before also but after reconnecting it was working fine. but n
I also want to know service center of iomega in delhi
  • Iomega Master
  • 27,725 Answers
Contact Iomega India: If you are looking for Iomega Customer Care Number and Service Center numbers in India then listed below is the information for your reference, you can contact the helpdesk for any queries you may have with regard to Iomega products you own.
Iomega has partnered with Neoteric in India who are the distributors of their Products in India, you can contact the below Customer Service Center numbers for any queries you have.
Phone Numbers:
Delhi - 011 - 46521468.
Bangalore - 080 - 42434112
Hyderabad - 040 - 6617829
Chennai - 044 - 424148439
Mumbai - 022 - 40049607
http://www.customercareinfo.in/
Posted on Nov 30, 2012
fire sine
  • 382 Answers
SOURCE: Unable to install IOMEGA HDD on Vista Home Premium
Vista may require drivers that are not preinstalled. If the drive clearly works on one machine, but not another, its safe to pressume its not the drive. On the VISTA machine, go to the Iomega site and download the driver for vista or usb or whatnot.
Posted on Oct 22, 2007
Beni S-P
  • 1006 Answers
SOURCE: iomega hard drive micro mini 8 gb
I know how to fix it but i dont know how to tell u couse my englisht is not so good..But we have another way:
be a (free) memmber of logmein.com and i need email adresse u have registred on logmein password and access windows password and i will fix it..I dont see other way to help you
Posted on Nov 05, 2007
trivialbrian
  • 8 Answers
SOURCE: Iomega 500GB data corrupted
The boot info is bad. If there is info that is needed you will have to use a recovery program like getdataback fat 32 and getdatabackntfs
Posted on Aug 02, 2009
  • 79 Answers
SOURCE: External HDD not recognized after a time of inactivity
you are guessing right... this is caused due to system going in standby suspend mode which powers down the HDD ... and when the system comes back from suspend mode... the win vista thinks no external HDD is attached to the system ... thereby removing it from the devices list.
right click desktop select properties and select screensaver tab and then power options. select turn off the hard disks and select never. this is for winxp .. but it will be similar to this procedure in vista.
Posted on Aug 07, 2009
SOURCE: my iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Posted on May 23, 2010
Cannot open drive E on Iomega zip 100
Assuming you have connected the drive and then restarted the computer with the drive connected and powered on... if it is model 31714 (not the same as the picture no power supply is required - if power supply is required make sure unit is powered on prior to connecting)
First guess at your problem. Your disks are formatted for a operating system other than what you are using. (Mac formatted disks on a PC or the other way around)
If you don't know how the disks were formatted you could test this by letting it get to the "insert disk" and then trying to right click and see if you have a format option ... note this will erase all information on the disks.. you will likely need to long format
Second guess the drive is bad... have seen cases where the drive is bad. If you have another computer you can use try hooking the computer up to another computer and see if you get the same result.
Let me know if this does not work and specific model number and op system I might have more ideas. I can also point you to a replacement If I know more about your system.
Feb 20, 2015 | Iomega Zip 100MB (31714) External ZIP...
Usb connector is broken from the Iomega LPHD-UP3. I replaced the HDD to an other case but the computer says I need to format the disk. I need an other case with the correct PCB connected to have acces
Yes, remove the drive from the case and connect it directly inside your computer. Then you should have full access unless the file system is corrupted which can be repaired with the chkdsk command.
Oct 03, 2014 | Iomega Computers & Internet
When turning on my laptop (DELL Inspiron 1545) the set up starts until I get the message 'BOOMTRG is missing, Press CTRL+ALT+DEL to restart'. Along with this, there is a yellow flashing light
This is an error message your operating system boot manager file is corrupted or missing. A clean re-install may solve the issue. Sometimes you need to format the entire HDD to install the OS. Remove the HDD from the drive bay and connect it to another pc using an external 2.5" case via usb cable and select that HDD from computer and rightclick then format. Select ntfs if needed. Untick the quick format and click OK. it takes a while to finish. After format complete remove the HDD and refit it in your laptop and re-install OS as usual. Hope this helps.
Dec 05, 2012 | Dell Red 15.6" Inspiron 1545 Laptop PC...
Need to reformat iomega 34275 from Mac to PC
Plug hdd to usb, after that, right click on my computer and go to manage, there go to disk management. You should see there all hard drives connected to your computer. Here localize your external hdd and see if it is initialized (you'l see in the right side of device the status), if it's not initialized right click on that area and initialize the hdd. After that go on the left side again right click and there could be two ways to format these hdd
1. if windows see something on hdd right click and go to format and follow the instructions from there
2. if windows don't see any partition there you must create one. Right click on hdd and select create new partition and after that follow instruction on your screen
Nov 13, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
It wont show/mount on my desktop
Have you ever connected this external harddrive to a macbook?
If you formatted it with your mac, it typically formats to a mac filesystem. What you would need to do is plug it back into the macbook, open up Disk Utilities, and then, after choosing your ext. hdd. you tell it to format into the EXFAT format. which is compatible with both systems.
Mar 12, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a iomega external hard disk and I did a repartition of the HDD and when I connect it to the TV, only the first disk partition is displayed? how can I see the other disk in the TV?
The OS of the TV probably doesn't allow for multiple partitions. And depending on the format you chose for each partition, one may show up while the other won't
Mar 05, 2011 | Iomega ScreenPlay
My hard disk iomega, model select from 320 gyga does not work anymore and is out of warranty ... the error message of my pc is that some files may be corrupted or damaged ... Software HDD Regenerator find...
> what can I do?
Open the case, remove the "dying" disk-drive, and purchase a new, compatible, disk-drive, and "transplant" it into the enclosure, thus reviving your external storage device.
Dec 30, 2010 | Iomega Select 320GB USB 2.0 Black Portable...
Cannot format external HDD vista OS
Right click my computer - Manage-Storage-Disk Management and then try to format from there .
Oct 25, 2009 | Iomega HDD External Desktop (32660) 80 GB...
NTFS hard disk not recognized as 'RAW' iomega hdd160
format this with NTFS to recognize by your computer, RAW means no file system
Dec 02, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Iomega 500GB Prestige USB 2.0 Portable Compact Edition Hard Drive Logo
291 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
