Question about Mercury P4VM800M7 Motherboard
I have a mercury board kob p4266ndfsmx, with intel processor and 1 gb ram, dvd writer is working fine, problem is im not able to boot from cd rom even if i choose cdrom as 1st boot device, i have check change everything i change cd rom, i tried different bootable cd, i can boot from cd if i disconnect hardisk but when i connect hard disk and choose to boot from cd, it will skip cd and directly boot from harddisk..also if i choose hard disk not installed in bios and boot from cd, it will boot from cd even i can format and install on it, this is a unique problem iam facing.. what is the solution for it...i think the bios is corrupted.. anyone can help
  • 105 Answers
Sometime there are an option in the BIOS setting to boot directly on HDD when there are a OS installed try to invert primary and secondary controller (invert HDD and CD-ROM wire on the motherboard)
Posted on Nov 29, 2012
5 Suggested Answers
  • 87 Answers
SOURCE: Not able to boot in normal mode or with bootable CD
You almost certainly have a virus.. these problems are usually caused by 'rootkit' virus. .these are virus's that your standard virus S/W can't see..
Download 'Unhackme' (google it) and install it.. Unhackme will get the virus BEFORE Windows loads.. it needs to be trained.. so follow the simple instructions as it can't alwyas tell the difference between a legit file and a dud.. it will fix your problem and make your system go faster too!
Posted on Jun 03, 2009
map9966
  • 2351 Answers
SOURCE: Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
  • 4 Answers
SOURCE: SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
OR
Find the drivers for sata device and install
Posted on Feb 20, 2009
multilinkent
  • 739 Answers
SOURCE: My Hard disk worked on other pc other hard disk
The first way to solve your problem is to make recovery of your operating system using your operating system cd.
There you can use a variety of ways to make the recovery cd with the operating system which is the operating system patch(Reinstall windows) or you can use the command promp
fixboot and chkdsk / r on the menu on the cd repair the operating system. (If you already started to boot up from CD, this menu will appear)
If there is no other way you had to reformat the computer to solve problems.
Posted on Jul 23, 2010
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
I have intel 101 Ggc Mother board and intel pentium D processor , i was using 756MB ram (512+ 256MB) RAM. But after i brought 1 GB ram and Used it instead of 256 MB Ram the system started restarting...
There is a chance that you have faulty RAM module. If computer is stable on POST (until Windows boot-up) I would suggest to use some testing tools to test that RAM with your motherboard. There is a good program called MemTest. You can find it online if you search Hirens Boot CD. Download it, burn image to disk, put 1GB RAM into motherboard, start-up PC and boot from CD. Then you'll search for Memtest program. I would suggest to leave PC for at least 6 hours for testing to find out if it's faulty or not (better to leave for 24 hours).
Aug 17, 2011 | Intel D101GGC Motherboard
I have a dell computer running windows vista home premium. Intel 2 duo core processor, 2 gb of ram, and 32 bit system. HL-DT-ST DVDRAM GSA-T10N dvd rom drive that is not properly reading my DVD's. It reads...
If your computer is still under WARRANTY, exercise that warranty to get it fixed.
Otherwise, spend $40 to buy a new CD/DVD reader/writer, to replace the "defective" unit.
Oct 15, 2010 | Computers & Internet
I have LG Dvd writer which i bought in aug 2009.this writer works well up to 15 days and from 16 th day it has a problem that whenever i play any dvd or cd it the pc is hang and when i play cd or dvd movie...
your computer might be slow if ur conf. is low, upgrade ur ram and processor. if ur ram is small then it happens.if it still hapens reinstall the nero burner
Sep 01, 2009 | LG GH22LS50 DVD-RAM Burner
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
configuration)
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
required
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
updates
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
Sep 28, 2008 | HP Computers & Internet
LG DVD WRITER NOT WRITING, ONLY READING.
you currently have a CD writable drive and a DVD readable drive which means you can burn CDs and play DVDs but not burn DVDs
Jul 30, 2008 | Samsung ( TS-H492A/WBEH)...
Laptop
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
To u my friend
nothing much buddy ...
HDD: 40 GB
Weight: 2.38 KG
O.S.: Linux
Price: Rs. 27,999*
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 37,999*
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Model No: Aspire 5502ZNWXCi
Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
HDD: 60 GB
Optical Drive: DVD+CDRW Combo Drive
Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
Weight: 2.38 KG
Battery: 6-cell Battery
O.S. : Linux
Price: Rs. 40,499*
Model No: AS 1641NWLMi
Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
RAM: 256 MB DDR2 533 RAM
HDD: 60 GB
Optical Drive: 8X DVD-Dual Double Layer Drive
Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
Weight: 2.38 KG
Battery: 4-cell Battery
O.S. : Linux
Warranty 1-Year Global Warranty
Price: Rs. 42,499*
Apr 14, 2008 | Computers & Internet
Is the 350 watt power supply ok for EVGA 6800 128 mb agp card ?
I would suggest at least a 400 watt power supply as the amount of peripherals you are running will soon take up the 350 watt supply, but go for a 500w as the price difference is negligable.
Mar 20, 2007 | Evga e-GeForce 6800 (128 MB) Graphic Card
Mercury P4VM800M7 Motherboard Logo
143 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
