Question about HP Computers & Internet
My desktop won't show
When I boot up my pc the desktop does not appear
  • HP Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
Hope this helps.
Posted on Nov 29, 2012
3 Suggested Answers
  • 17 Answers
SOURCE: Desktop icons do not appear when I boot up the
It sounds like your profile has a fault. In C:\Docs & Settings, there will be a folder with your username against it. Rename this folder and then restart the machine and logon again. It will create a new profile. You can then copy your docs, etc back to your new profile. If this doesn't work, I would suggest a software rebuild.
Posted on Sep 30, 2009
  • 139 Answers
SOURCE: Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Posted on Apr 06, 2012
Acer eMachines 200 desktop won't boot up
What isit configured to be theboot device?
Apr 14, 2013 | Acer Computers & Internet
It won't finish the start up
It is looking for something to boot from. Remove any CD and USB drives. Then try physically reconnecting the drive. From there you will need to verify in BIOS.
Check first boot in BIOS as well.
Jan 31, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Cant access bios to change boot order to reuinstall windows 7
Boot the computer and watch the screen. It will tell you what key to hit to get into the Bios or System Setup. You have to hit the key when you see the message or it won't work and you will have to restart.
It also shows you which key to hit to change the Boot Sequence or Boot Order. But you have to hit the key when the message appears on the screen or it won't work and you'll have to reboot. This is a temporary 1 time change for the current boot cycle. When you change it in the Bios or System Setup it's a permanent change.
May 25, 2012 | Computers & Internet
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
I have an acer aspire z5600-U2092 all in one pc desktop, but my problem was when i bring it home here in the philippines on the first week i can still use it but it happens on the next day when i want to...
SYSTEM RESTORE Windows XP
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Oct 18, 2011 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
System won't boot pass the logo screen
PRESS F8 A FEW TIMES WHEN YOUR WINDOWS LOGO APPEARS GO TO SAVE MODE WITH NETWORK,GO TO YOUR C: RIGHT CLICK,PROPERTIES,TOOLS, CHECK FOR ERRORS,SCHEDULE ,OK OK REBOOT AND WAIT TILL IT'S FINISHED. OR WHEN YOU LOGO APPEARS SEE IF IT'S F? FOR RECOVERY AND CHOOSE REPAIR
Oct 13, 2011 | Compaq Presario 5000 PC Desktop
I have an HP1110n....It acts like it is booting up, but I only see my screen background pic. No icons show up. The disk spins and is doing something, but it won't display ANY icons ! Help !
This happens when Explorer (the file manager - the program that makes all the files visible on the screen) doesn't starts at boot. Press Alt + Ctrl + Del to open Task Manager. Click File, click Run and type explorer. Click OK and the icons and the taskbar will appear. If it doesn't start or it's faulty in any way you will have to reinstall Windows.
Jul 31, 2011 | HP Pavilion a1110n (PX743AA) PC Desktop
On startup my S3220N PC setup menu appears and won't leave until I go into the boot menu and select the hard drive-this adds 5 minutes to the startup
ok this you need to replace the cmos battery. is a coin cell of 5v its the most commmon and it keep a record of boot config..if something goes wrong with it you need to set up every start up.....
Jul 04, 2011 | HP Hewlett Packard Pavilion Slimline...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
