Question about Samsung HCN529W 52" Rear Projection Television
Remove lamp housing unit from 50" dlp model HL-P5063W
I have viewed how to replace Lamp within the housing unit which looks fairly easy. However, when removing the back cover and viewing the housing unit, I can not see how to remove it and there are a few delicate wires in front which concern me. I did remove the visible screws and the unit did not budge. How can the unit be removed?
  • bfdawson59 Jan 10, 2009
    The TV is Samsung 50" dlp model HL-P5063W SVC MODEL HLP5063WX/XAA WITH A LAMP CODE: BP96-00608A SIZE "B" WITH ROUND LAMP
  • bfdawson59 Jan 15, 2009
    I Have not received an answer to how to remove the lamp housing unit from the TV. I did not see how a few pictures were relevant.
    Sergeant:
    Novelist:
  • 326 Answers
Http://www.flickr.com/photos/fixyourdlpcom/
click the link directly and follow the instructions
Posted on Jan 10, 2009
  • 10,594 Answers
Hi, let me know exact model of TV to help you.
  • Shahid Electronics
    Shahid Electronics Jan 10, 2009
    Thanks for update,
    HERE is pictorial how to replace lamp I hope this will help you in lamp replacement.
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
Aug 10, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung DLP, model hlp5063w. When I turn it on, the picture comes on and a few seconds it kicks off. After a few more seconds, it turns back on. It keeps turning on and off until I unplug it. Any...
2 most common causes of that sympton would be
1. Lamp failure is the most logical culprit BP96-01403a is the lamp number and I recommend only using an OEM replacement
2. Color wheel malfunction. Usually when the wheel fails you will hear a very loud motor spinning sound from within the tv.
If you havent replaced the bulb in a couple years that would be the most logical cause.
Oct 28, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Dlp samsung
There are instructions to replace the lamp in the user's manual. The light comes up but if the lamp has now already several hours of use the resistance of the lamp increases and shut down the power supply of the lamp. Second, the lamp power supply could be bad too, but lets be optimistic and just replace the lamp first.
Apr 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HCN529W 52" Rear Projection Television Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
