Question about Hoover Vacuums
Height adjustment on Hoover Windtunnel u5755-900 no longer works
The height adjustment on my Hoover Windtunnel u5755-900 no longer works. It's stuck in high position so I'm getting no suction from carpet.
  • Anonymous Mar 24, 2014
    the height adjustment know or panel underneath will no longer adjust for short carpet to long. how do i fix?
  • 294 Answers
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
Posted on Jan 18, 2009
Hoover Wind Tunnel Bagless problem with carpet hight adjustment
Hi There Alec from VacuumSpot here.
Most of these machines don't actually change the height until the handle is lowered so even though you change the dial when it is an upright position it is not until you lower the handle that the height is actually selected. Assuming that you are aware of this and it is still not adjusting I would suspect you have a small arm or lever broken. It is very rare for a height selector to simply fall out of place.The job would take 5 minutes in my opinion so it is simple but a bit fiddly.
Dec 01, 2012 | Hoover U6630-900 WindTunnel Bagless...
Beater brush will not operate
No site available for that, but the height adjustment on this machine only works when you let the handle down.
Nov 26, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Height adjustment won't work on Hoover windtunnel
In my experience, Hoover height adjustment are "stops" rather than being attached to an axel. Look for something that rould resemble a set of circular steps somewhere in the path the axel would take as it goes up and down. It is usually on the underside from the knob that sets the height. Each 'step' represents a height with the shortest step being the lowest setting from a certain perspective.
On some Hoovers, therte is a ratchet petal on the right side. The ones I have seen are similar in operation to the above.
Let me know if this helps you.
A
Sep 21, 2009 | Vacuums
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
Height adjustment
this usually means your belt is worn.
Feb 26, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
Sounds like you have a bad brush roll(48414115), take it out and see the the ends turn freely or not, if not, then replace it. Also check the the slots that the brush roll sits in to make sure they haven't melted. I am assuming that the motor is running, if not, then it may have froze up.
Feb 28, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
1,018 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
