Question about Sewing Machines
How to open a Thumper VersaPro foot massager (there is no visible screws) ?
  • 3 Answers
They are probably under the squishy feet. use a flat something and gently pry the feet off and I bet they will be under there. also if there are any stickers you can usually see the indention of possible screw holes. use a flash light. I highly suggest viewing under a brighter light . you can see what you are up against.
Posted on Nov 29, 2012
Foot not tight enough against feed dog to hold fabric as I sew.
The foot always has an adjustment screw that is above the foot. Follow the foot arm directly above the foot. It will have a little screw above the foot that turns. You may have to open the front of the machine where you will see a small numbered gadget; round or star shaped usually. Anyway, this will have to be adjusted by the sewing individual. If it can't seem to be adjusted to hold the fabric the foot arm length needs to be adjusted by a repairman. Anyway, go to utube and type "adjust sewing foot pressure" for an easy lesson.
Aug 23, 2017 | Sewing Machines
Feet for Acuvibe 5004 foot massager
Take one of the rubber feet to the hardware store and see if they can sell you replacements.
Oct 10, 2016 | Sewing Machines
Repairing a Singer Sewing machine presser foot lifter.
Inside the foot the wires are connected to two different screws. They are obviously coming loose by being pulled.
1. Open the foot on the bottom.
2. Look where the screws are. You need to have the wires connected there.
3. Before connecting to screws: tie a knot in the wire from the inside of the foot pedal where the wire protrudes through the hole.
4. Now, tightly connect the wire to each screw. Apply bottom of bracket. Now, sew!!!!!!!!!!
Sep 23, 2016 | Singer Sewing Machines
I undid the screw of the foot shaft without a foot on it and the shaft dropped to the plate. I have levered it up and put foot on but the foot wont lift, can you advise me how to fix this please?
there two holes on the side plate where the presser ft bar is located. take off the rubber cover and a screw will be visible. this screw controls the presser ft. height and angle of ft. place ft all the way down and cnter needle in foot slot and them tighten screw. use an long screw driver because u get more leverage. in fact long screwdrivers are the only thing to use on machines. every one should be ground to fit the different screws. anyway raise the foot to see how much clearence u have and adjust accordingly.
Aug 06, 2014 | Juki DDL-5550 Industrial Straight Stitch...
How do I take the machine apart #7469? Where I plug in the foot the plug thing went into the machine
I'm not sure I understand the problem. Is it the foot pedal that you want to remove or is there a problem with it? Exactly what is the problem you're having?
Apr 19, 2013 | Singer Confidence 7469 Mechanical Sewing...
How to unassemble and clean Janome sewing machine foot controller model 21371?
There are 4 screws on the bottom, 2 are under a rubber pad that can just as well be discarded. Be careful opening the 2 halves of the case, since the assembly is spring loaded. Note carefully the position of the wire bail as you open.
Your control is failing because the two resistive strips are dirty. Blow all the lint out the the case, and swab the two resistor strips with alcohol. Move the wiper arm so you can reach both ends of the strips.
To re-assemble, lay the bottom half on the table and place the plunger and wire bail in position. Then set the large ends of the springs over the round plastic projections in the plunger. Take the top half of the case (with all electrical parts) and engage the bottom end (away from the springs). Before pushing the top half closed, be sure that the small ends of the two springs fit around two screw heads.
May 13, 2012 | Sewing Machines
How do i install the darning foot?
Make sure that you have a darning foot that is compatible with your machine. I believe that the 7422 is a low shank foot; the appropriate daning foot is http://www.sewingpartsonline.com/darning-foot-singer-006016008.aspx . Lift the presser foot and remove the foot currently on the machine, including the ankle. (Loosen the screw on the left side of the ankle.)
Place the darning plate over the regular plate and feed dogs. The pins should lock into the spots on the machine.
Place the U-shaped opening of the darning foot over the screw that you loosened previously. Then tighten the screw to hold the foot on the machine.
Lower the presser foot onto your fabric. Set your stitch length. Lower the lever on the right side of the darning foot and hold onto your top thread (assuming the needle and bobbin thread are already threaded.) Now sew.
I hope this helps.
Aug 10, 2011 | Singer 7422
I need to buy a replacement foot for my shark euro pro x 361 sewing machine where can I buy this.
e mail to rocklandmedical@gmail.com or call them at 845-694-4961 and leave a massage
May 20, 2010 | Euro-Pro Shark 60 - 384
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Dec 31, 2009 | Singer Sewing Machines
Brother SE270D
there is also a single screw on the bottom of the machine as well as one behind the bobbin winder, the last 'hidden" one is on the back side of the machine behind what woudl be the reverse button.
Jan 12, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
75 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
