Question about Covercraft Personal Watercraft Cover - YAMAHA Wave Runner XLT 1200 (2001-05), XLT 800 (2002-04) - w/ rear tie down opening
2000 yamaha 1200gp doesnt have dash lights and when you push start button it macks a buzzing sound in the black box where the ignition leads go,,,,any one out there can help me?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Covercraft Master
  • 1,190 Answers
Battery flat or starter solinoid needs replacin !
Posted on Jun 04, 2014
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
I have a 2000 Jaguar s-type, and my battery died, but I can only find my valet key are there any other options to getting in the trunk? please help.
Open the door and remove the fuse box cover at the bottem of the A post. You might have to remove more of the plastic trim and take a positive lead from a battery to the red stud and take the black earth to the body this will power the boot.
Feb 24, 2015 | 2000 Jaguar S-Type
When I turn on the blinkers , , I hear a buzz sound , and then the insturment panel lights up ?
I just had a buzzing sound happening on my 2000 Monte Carlo. It was coming from the Hazard button which is actually combination blinker\hazard switch in one. Turns out the ignition switch was going bad. The ignition switch finally went totally bad (no start some times). Changed it a couple of months ago. No issues with blinkers again.
Sep 05, 2012 | 2000 Chevrolet Monte Carlo
1999 Yamaha 1200GP Wave Runner wont' start. It has sat for about 2 years. I have new battery, new plugs and new gas, it turns over but won't start, any suggestions?
Sounds like the carbs are gummed up from the old gas sitting in them. Remove the carbs, disassemble, clean with a carb cleaner, and reassemble.
May 14, 2012 | Motorcycles
My 1986 yamaha xz 400 will not start lights on dash go etc but when i tu rn key it just clicks has always started first go up to now have checked battery fuses
starter solenoid.take battery an battery box out.solenoid is an inch round diameterand bout 3inches long with positive lead to battery and to the starter. if you want u can jump staft from tbe battery to th ztarter on the bottom front of the motor.you need to check your regulator rectifier bolted to the back of the battery box.withe fins on it about 4inches square . lots of wires go to it.these become faulty and cook your battery and starter solenoid.hope this helps.you can push start it aswell...420tristan@gmail.com
Aug 27, 2010 | 1985 Yamaha XZ 550
When starting,all lights are on,tail light is dim,when i push the start button i only hear a buzzing low sound.
Sounds like a dead battery to me. To make certain, use a volt meter and connect it across your battery, red lead to positive, black lead to negative. Press the starter button, if he voltage drops below 10 volts, your battery is kaput.
Or, if you don't have a volt meter, take the battery to an automotive parts store and ask them to load test it for you. They'll usually do this at no charge.
Good Luck
Steve
Aug 22, 2010 | Harley Davidson FXD - FXDI Dyna Super...
I have a yamaha 450 big bear it wont start off the button ,i have 2 live feeds going in to the solenoid when the ignition is on if i short the solenoid across it turns over and starts any idears?cheers...
Listen near the solenoid while trying to start--if you get a fairly loud 'click', the primary circuit is ok, but the solenoid heavy contacts are not making--repair or replace the solenoid if sealed. If no click, check the small terminals with a test light. The light should go out on one when the start switch is pushed. If the light never comes on, check the other small terminal--it should be lit at all times whenever the ignition switch is on, even when the start switch is pushed. If it goes out too, there is a poor connection between the ignition switch and the solenoid. If neither terminal loses power, trace the start button circuit back to the solenoid. It is likely open somewhere between--usually a push-together connection. Hope this make sense and helps!
May 07, 2010 | 2000 Yamaha WR 400 F
My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Apr 05, 2009 | Vehicle Parts & Accessories
Covercraft Personal Watercraft Cover - YAMAHA Wave Runner XLT 1200 (2001-05), XLT 800 (2002-04) - w/ rear tie down opening Logo
109 people viewed this question
Top Covercraft Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Covercraft Boating Expert? Answer questions, earn points and help others
