Question about Nordic Track Nodictrack A2250 Console Treadmill
When I plug my Nordictrack A2250 in the fan runs and the screen is blue, none of the buttons work. This is without the safety pin attached.
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) replace batteries with the same type, same mark, same polarity
3)clean contacts spring with c. cleaner spray. buy it from some electronic store.
God bless you
When I plug my Nordictrack A2250 in the fan runs a - 11_29_2012_11_28_07_am.gif11_29_2012_11_28_23_am.gif
Posted on Nov 29, 2012
SOURCE: I have a NordicTrack A2250, about 2 years old.
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
Posted on Dec 19, 2009
  • 218 Answers
SOURCE: my nordictrack a2250 only beeps
the console software is damaged and the console will need replaced
Posted on Aug 11, 2010
  • 218 Answers
SOURCE: My nordictrack a2250 turns on, the incline works,
the motor controller is bad and needs replaced
Posted on Aug 13, 2010
  • 20 Answers
SOURCE: i have a nordictrack a2250 when run on it the belt
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
Posted on Nov 09, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
My NordicTrack A2250 treadmill display is flickering. The unit runs perfectly well. Can this be repaired?
Hey Alfred, yes it can be repaired,,, but in the interest of saving $$$$,, if it runs... just jump on and go until you have had enough... the rest is really trivial..think about it..
Jul 12, 2017 | NordicTrack Exercise & Fitness
Hi, I have a NordicTrack T5.7. When I plug it in & turn it on, it seems as though the screen is "running" without the belt running & tracking an exercise without the safety key on. But when I put the...
BEFORE performing this solution Make sure power to this unit is turned off and unplugged!!!!!
Most if not all treadmills have some form of safety device that checks yo make sure the tread main rollers are aligned with the motor. ussualy on the frame or little tin flange near the main drive roller, it could be a small switch or an IR sensor but WILL be very near ie: 1/8th of an inch or so. these often get there tin flange bent during moving, cleaning, lubrication etc. ( His little tin flange got bent sounds like a bad misfit toy story) If this is the case simply straighten or realign the sensor Your owners manual may even refer to this sensor.
I hope this helps
Nov 20, 2013 | Exercise & Fitness
Nordictrack c2150 panel not working
adjust the Reed SWITCH, see the diagram attached it. Clean it, test it of open or faulty. Tight the connector very well. Replace and clean the contacts batteries( if they have).
Tight the ribbon cable inside.
If the problem persist, after you did, replace control display board
God bless you099b95f6-0273-44db-b9a8-431d1bfaedf5.gif242bb3fe-383b-4bdb-aa92-fe8728465711.gif
Jul 25, 2013 | Exercise & Fitness
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Apr 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a NordicTrack A2250, about 2 years old. When it's turned on, the control panel lights up, and when I insert a program chip, the console "speaks". However, the neither the incline nor the belt...
Dec 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Nodictrack A2250 Console Treadmill Logo
144 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
