Only plays one track from from DVD sound
I have an old Philips DFR 1500 DVD/CD player - Digital AV Surround Receiver and it's playing just one sound track of from a CD. I get picture OK but only what appears to be the secondary sound track.
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Posted on Jan 11, 2009
My surround sound won't work now when I play the dvd player
Could be many things - I know, bad answer. There is no simple answer or fix.
Without more info one can only speculate.
Please determine and answer as many or all of the following so that we can help.
1) What is the make and model number of the Surround sound unit?
2) What is the make and model of the DVD player?
3) How is the DVD player connected to the Surround sound unit?
3a) Is it connected via an HDMI cable?
3b) Does the DVD player have regular stereo connections that you are using (we call these analog audio connectors)?
3c) does the DVD player have digital audio outputs that are connected to the Surround sound receiver?
4) Did the DVD player EVER make sound?
4a) if yes - what changed?
4b) if yes - does this happen with different discs?
Now some general points.
I'll assume that the other sources do work and play sound through all speakers when they are supposed to play sound through all speakers.
Then - I'll assume that without changing anything else you select the DVD player input that used to make sound but doesn't now.
Problem could be the encoding option that you have selected when you play the disc.
Many DVD's and Bluray's have audio options that you can select from the disc's main menu.
Dolby digital is the most common - also known as AC3.
Some discs have another digital audio track called DTS.
Not all surround receivers can decode all formats.
Even if your surround receiver claims to be able to decode AC3 and DTS, they will not if you don't connect the correct cable to the receiver and usually map the input to the correct digital audio connection that you are using OR if your DVD player is not capable of outputting all formats.
There are many different ways to connect the gear and many different ways one can configure correctly or not; all contributing to whether you get sound or not.
So in the above example - by selecting DTS, you do not get any sound - then try another audio track option. Basic stereo usually works (also know as PCM - which is audio like a CD).
OR maybe you never properly configured the audio properties of the DVD player.
Go into the DVD's menu or set up options and see what you find but make sure you know how the DVD is connected to your surround receiver!
As you can see - there is no simple answer without a lengthy Q and A exchange first.
May 26, 2014 | Yamaha Audio Players & Recorders
How do i hookup my memorex dvd player mvd2047 to my dish box to watch movies
I have a Philiphs DFR _1600 Surround Sound Receiver with Built in DVD Player . I Don't Have The Remote , I got the Dfr 1600
ay Gooodwill for $25 Dollars ,
I would like to ADJ The rear Speakers , Turn them up
Is There a Way to turn up the Rear Speakers on the Unit it,s Self .
with out a Remote .
My Kenwood Surround sound Unit has this on the front of the unit .
Thank you
Harry w
Dec 04, 2013 | Televison & Video
My Sanyo DP23845 23 In. LCD Television does not have any options under set up beside color-how do I add channels?
HDTV inherently provides a superior sound quality simply because the sound of HDTV is digitally transmitted. The difference in sound between an HDTV television and an analog television is rather noticeable. In fact, it is directly analogous to the difference between the music on CD's compared to the music on audiocassette tapes.
The difference in sound quality provided by HDTV televisions and programming does not end there. Many HDTV programs are also broadcast in Dolby Digital 5.1 surround sound, but in order to take full advantage of this technology, it is necessary to have the right equipment.
Dolby technology has been created by Dolby Laboratories, Inc. This technology is the most renowned provider of digital audio technology. Also, Dolby Laboratories is known for reliable and superior products. For these reasons, Dolby Digital Surround has become the standard for HDTV. Many television manufacturers substitute their own surround sound systems, but they cannot live up to the reputation and performance of Dolby. Therefore, it important to check the specs on an HDTV television before buying in order to ensure that it uses Dolby Digital Surround.
When using Dolby Digital Surround Sound, there are three options for set up. The first option is to buy a television with high quality center channel speakers, woofers, tweeters, and Dolby technology installed in the television. With this option, it is unnecessary to buy addition equipment to take advantage of Dolby Digital Surround Sound.
Another option for taking advantage of the Dolby Digital Surround Sound with an HDTV is to connect an external set of surround speakers to the television. With this option, the surround sound set up includes a front pair of speakers, a surround pair of speakers, a center channel, and a subwoofer. Sometimes, the front speakers are "powered towers." This means these towers include subwoofers.
The placement of these speakers is very important for the quality of the surround sound. The Center Channel Speaker should be centered either above or below the television. The Front Left and Right Speakers should be placed in an arc formation in line with the Center Channel Speaker. The Surround Left and Right Speakers, on the other hand, should be placed to the left and right sides behind the listening position. Many people choose to wall mount these speakers.
The third option for taking advantage of the Dolby Digital Surround System included in an HDTV television is to use an external set of front speakers can be connected to the HDTV television. This configuration is useful if there is not enough room to set up the external surround sound system and the HDTV does not come with Dolby Digital Surround installed. This isn't true surround sound, but it is a viable alternative to those who can't take advantage of the first two formats.
The audio and video outputs of the DVD or VCR can be connected to the AV receiver's video outputs. If a separate DVD and VCR need to be connected, one can be connected to the VCR1 connection and the other can be connected to the VCR2 connection. The AV receiver's VCR video and audio outputs should then be connected to the audio and video inputs of the DVD and/or VCR. In this way, the DVD and/or VCR will be able to record video signals that come through the AV receiver and the VHS tapes and/or DVD's will be able to be viewed on the HDTV.
To take full advantage of the Dolby Digital Surround Sound technology, one of the video outputs of the DVD player and/or VCR needs to be connected to the AV receiver. The digital coaxial audio or digital optical connection must also be connected to the AV receiver.
How do I connect my CD player?
A CD player can be connected to an AV receiver. The CD player's digital audio outputs can be used to connect the CD player to the AV receiver. A CD-Recorder can also be connected the AV receiver by using the Audio Tape Record/Playback input/output loop connections. In this way, the CD-Recorder will be able to function much like a standard audiocassette deck.
What else will I need?
Besides the basic electronic equipment needed to set up Dolby Digital Surround Sound, it is necessary to have connection cables. This includes video, audio, and loudspeaker connection cables. These cables need to be at an appropriate length in order to set the speakers in the proper position for optimal surround sound quality.
Jul 29, 2012 | Sanyo DP23845 23 in. LCD Television
Unable to set surround sound to work
The media you are playing must have surround sound recorded or encoded on it in order for surround sound to play or occur. Get a DVD or CD that has surround sound stated on the label - otherwise the system defaults to stereo playback.
Oct 31, 2010 | Nakamichi AV-10 Receiver
Makes a buzzing/humming sound when playing a dvd or cd
that is a problem with the amp.
does this player have a dvd player built in or not
May 11, 2009 | Televison & Video
Philips DFR 1500 Service Manual or where to find parts!
how do i turn up the two rear surround speakers on my philips dfr 1500
Mar 16, 2009 | Philips Audio Players & Recorders
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
