Question about EliteGroup Computers & Internet
Connecting 9 pin reset cable - EliteGroup Computers & Internet
2 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: I bought a new computer
Please refer to this:
And this:
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Feb 17, 2011
What are front panel connections on motherboard?
Font panel connections are the power and reset buttons and status led's.
front-panel-connections-motherboard-u2of3ikpdsr23qnsqxf3hbc3-2-0.jpg Ignore pin 9
The color order on the reset and power switch are not important but see that you insert the colored cable to the power led to pin 2 and the colored cable for the hdd led on pin 1
Oct 05, 2015 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Jan 15, 2011 | AOpen AX45-4D Max Motherboard
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
1 9
HDD Led + in pin 1
HDD Led - in pin 3
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
To connect gps to computer wich pins do i connect of nmea cable?
pins 2(-) and 5(+) on a 9 pin serial cable, then you need a usb to serial adapter for input into the computer if you do not have a built in 9 pin serial port on you computer because the usb moves the information faster than the gps signal. gps is roughly 4800 baud, usb is moving so much faster you need a buffer
May 19, 2010 | Furuno GP32 GPS Receiver
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Manual?
    The connections are show between the last 2 PCI slots. The connector is CN1A.
    Here are the connections.
    1 & 2 = G Button
    3 & 4 = HDD Led + to pin 3
    3 & 9 = Power Led + to pin 9
    6 & 12 = Speaker + to pin 12
    11 & 13 = Power switch
    14 & 16 Reset switch
    17 & 18 = G Led + to pin 18
    15 is keyway [no pin]
    [2 4 6 8 10 12 14 16 18]
    [1 3 5 7 9 11 13 15 17 ]
    Sep 14, 2007 | Chaintech 7NJL3 Motherboard
    Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
    Hello Clifford,
    This is an old message. Are you still having trouble with this or has it been resolved?
    Aug 22, 2007 | Raymarine C80 GPS Receiver
    Computers & Internet Logo
    132 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Matthew Spark
    Matthew Spark
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
