Question about Air Tools & Compressors
I have a 500hp ingersoll rand compressor. I don't
  • 843 Answers
Maybe you have residual coolant still in the lines from the leak you have already fixed and you just need to thoroughly blow them out? If the coolant is not just water maybe you need to rinse them out? Good luck!
Posted on Nov 30, 2012
  • wayne Nov 30, 2012
    I'm losing about 10 gallons in less than 8 hrs. I'm surprised my nlm has held up and still doing its job down stream
3 Suggested Answers
  • 104 Answers
SOURCE: compressor oil
PLease contact IR http://www.irtools.com/serviceandsupport/techpubs.aspx
and direct this question to them. You do not want to make a mistake here as it will cost you a compressor. I would only accept what IR says is acceptable
good luck
Posted on Mar 17, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I am looking for a service manual for a INGERSOL RAND P130SD machine
Doosan have now taken over all Ingersoll Rand Portable Air Compressors, if you contact them they are normally very helpful.
Nov 18, 2011 | Ingersoll Air Tools & Compressors
Where can I get an oil fill drain plug for ingersoll rand compressor 2340L5-V?
There are alot of resources to obtain this. I would search the net or you can contact ingersoll. the 800 # on the unit would be a good place to start.
Jan 29, 2011 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
WHAT TYPE OF OIL CAN I USE IN MY TYPE 30 COMPRESSOR
I am sure Ingersoll Rand would like you to use there all season select synthetic oil, or you can use a good quality R+O 100 oil, also known as SAE30 non detergent. do not use cheap oil for gas engines,,, buy a good name brand from a regular oil distributor, and specify yo are using it for an air compressor. and most manufactures will recommend you change it every 3 months.
Jan 08, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
Air Tools & Compressors Logo
51 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
