Question about RCA RT2380 Home Theatre System System
How do I get my RT2390 Home Theater System to work with the digital audio in connection, my TV is a Emerson LC320EM3F
I am trying to getmy Emerson LC320M3F to work with my RCA RT2390 Home Theater System
SOURCE: home theater RCA RT2620
Try opening it up and unplug everything that you can (some of them you can't) and for some reseason it resets. I did that to mine and now it works.
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
SOURCE: I have a RCA RTD315W home theater system. Are the
I have a RCA DVD Home Theater System, RTD315W. The "On/Standby" light is on (displaying a blue light), no other features are working. When I press a feature buttom, the blue light goes out. System just isn't working. System haven't been exposed to water/moisture. What the problem?
Posted on Sep 02, 2010
  • 334 Answers
SOURCE: i have rca home theater system rtd215 plays dvds
This reson you are not hearing any "TV AUDIO" through your RCA surround system would be due to your tv sound output not being connected to an audio input into your surround system. You can hear DVDs,CDs and radio possibly mp3 if connected, as these are built in to the amplifier which the speakers connect to.
If the tv has a Line out (via phono plugs) and NOT via headphone out, connect it to an audio input on the RCA surround system. If the RCA has no other available inputs, well....there ain't a lot you can do but watch CSI with the sound from the TV and then Star Wars (for example) through the TV and Surround system.
Best Of Luck
Posted on Sep 03, 2010
Testimonial: "thank you very much"
SOURCE: I bought the RCA RTD325W DVD home theater system.
Your TV must have a set of Audio Out connections. Connect them to the Aux In on the back of the RTD325W. Then toggle the Line-In/Aux button on the remote until display reads Aux In. System should work.
Posted on Dec 07, 2010
I want to upgrade to a 4k tv but my home theater does not support 4k. Can i run sound only thru it?
You can run the sound to the home theater system in many cases. It depends on the home theater system and the TV. If the home theater system has a digital audio input, it is easy to connect most 4K TVs. Connect the 4K source to the HDMI or Displayport connector on the TV. Check whether the digital audio uses an optical cable or a coaxial cable. Make sure that the TV has the matching output and get the correct cable. Set the TV to use external speakers (under the Audio part of the setup on most TVs) and turn off the internal speakers.
Very few 4K TVs have analog audio output. If your home theater system only has HDMI and analog (RCA red/white) audio inputs, you will need a digital to analog audio converter and both digital and analog audio cables. The converter will look like this: https://www.amazon.com/Gefen-Digital-Adapter-Converter-GTV-DIGAUD-2-AAUD/dp/B0013LWK3A .
I hope this helps. Please add a comment with the make and model of your home theater system if you need a more specific set of details about doing this.
Nov 20, 2016 | home Audio Players & Recorders
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Mar 03, 2013 | Coby DVD938 Theater System
Can i connect dmp-bd871 to a home theater system
It will depend on your home theater system and TV. If your system accepts HDMI in from other devices and HDMI out to the TV, connect an HDMI cable from the blue-ray player to an HDMI input on home theater system. Then connect another HDMI cable between the home theater system and the TV. This will provide the best video and audio experience.
Another option is connect the HDMI cable from the Blue-ray player to the TV. Connect the audio output of the TV to the home theater system. (This will depend on the TV as well as the home theater system. Some TVs have digital audio outputs; others have analog outputs. If your home theater system doesn't have the same input as the TV's output, you would need a converter as well as the digital and analog audio cables. This is an example of one for digital to analog: http://www.gefen.com/kvm/dproduct.jsp?prod_id=4907 .)
If you do not want to get the best picture from the Blue-ray player and your home theater system has analog audio inputs, you can connect the composite video out to the TV. Then connect the audio outputs from the player to your home theater system. (This means only an SD picture will be provided to your TV.)
Panasonic has the manual for the DMP-BD871 here: service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF .
I hope this helps. Please add a comment with the other devices in your entertainment system or their inputs/outputs. Then I can add specific information for your system and any tips for setting up the system.
Nov 26, 2012 | Panasonic DMP-BD871 Blu-ray Player with...
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
Optical audio doesnt seem to work... Does it need to be turned on and if so how do i do that?
put source on SAT. use the remote and hit "set up" use right arrow button until the word "coax" shows on unit, Now your digital.
Good Luck
Oct 14, 2010 | RCA RT2390 System
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
Home theater system hookup
have you enabled the external audio on the TV?
Nov 19, 2007 | Philips 42PFP5332D 42 in. Plasma...
RCA RT2380 Home Theatre System System Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
