If sony bravia get lay down on moving time can dammage the tv?
  • tv protecguy Nov 29, 2012
    i just upside down the tv when i wants to wrap that with the pad .so is there any problem if the tv is disconect from plug?
  • 32,281 Answers
No but be careful not to put pressure on the face of the screen because you might crack the glass and damage the screen.
Posted on Nov 29, 2012
3 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
Posted on Dec 24, 2010
SOURCE: "Guide" button makes Sony Bravia TV go to black screen
I am having the same problem with my newish Sony Bravia. There is only a black screen when I use the "GUIDE" button. And individual channels show "No program description".
Did you ever figure out the problem?
Thanks.
Posted on Jan 05, 2011
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
Feb 24, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Thanks.
Jul 10, 2010 | Sony Televison & Video
How do I remove the stand of the Sony Bravia XBR KDL-V40XBR1 so i can wall-mount the tv?
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Nov 26, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Moving country with Sony Bravia KDL-46W4100
What is exact model number of your Sony TV to check its specifications that it will work on 230V 50Hz
Jul 12, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Moving a 40" Sony LCD HDTV Bravia
I would suggest to use foam and bubble wrap to soften the vibration to the TV.
The TV should place in a vertical position.
Good Luck with your cross-country trip.
Jul 29, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
Electro Med Services...
