Question about LG Televison & Video
60py2dr can a dvd be played on one of these sets without a separate dvd player
  • LG Master
  • 32,281 Answers
If the TV has a built-in DVD player then you can play DVDs without adding a separate DVD player.
Posted on Nov 29, 2012
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Connect to a Panasonic home theatre/dvd player
You must hook up the DVD player in separate jacks into the TV with red, white, and yellow cables. To play the DVD player you must set the input in the TV menu
Dec 06, 2011 | LG 55 55LK520 LCD TV
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
Windows media player doesnt play dvd movies
Simply install a DVD player separately or DVD Codec for Window's Media Player. The reason why Window's Media Player can not play the DVD movies is that it does not has a DVD codec to play it. The simplest solution to do it is to install a DVD Player program and Window's Media Player will start playing DVD movies.
May 05, 2009 | Computers & Internet
Curtis DVD 5091 Home Theatre System
I believe I have the solution....but it depends on your dvd player's zuxilarily capabilities. Do you have a second set of OUTPUT plugs that are colored Red and White on the back of the TV? Do you have a separate Red and White INPUT plugs on the back of the dvd? The TV must use the speakers in the DVD system by pushing the sound OUT. You cannot accomplish this if the dvd is only pluged into the INPUT of the tv.
\Another option is o make sure your DVD player has a "auxilary" or separate input channel on the console or remote.
I have a DVD home theatre system as well, not the same brand, but that shouldn't make a difference . Its a matter of how the sound is received.
Hope that helped.
Apr 29, 2009 | Curtis DVD5091 Theater System
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
When dvd plays radio comes through as well.
This unit needs to go out for service. There is an issue inside the circuitry in the unit.
Gary
Nov 22, 2008 | Denon AVR-2803 Receiver
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
