Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Put icon back in toolbar
I somehow removed all my icons from the start menu and I've attempted to put them back. But the icon that is usually in the toolbar near the clock is gone. This icon tells me how much space is on the drive and its health and such. please advice.
  • dbridges79 Jan 10, 2009
    I looked in those places and for some reason they aren't there. But when i log onto the guest account its there just like when i first installed the drive
    please help
    in know its not even in the past icons area. just gone
  • 3 Answers
Left click on the toolbar, then select properties. Then click on the tab that says notification area, then select the ones you want. I don't know if that's all the icons you wanted. Hope it helps.
Posted on Jan 10, 2009
  • OregonDucks
    OregonDucks Jan 10, 2009
    Also for the start menu problem right click on the toolbar and select properties and go to start menu, then select start menu tab and click customize and that should be how you get those icons back.
  • OregonDucks
How do i delete my favourites toolbar
How to remove toolbars
On your browser like IE9
Go to tools
Find toolbars on the menu
Click on toolbars
Uncheck favorites toolbar
And the toolbar will go away
How to delete icons on the toolbars
Go to tools
Go to toolbars
Click on the toolbar option
Go to Customize
In the menu you can add which buttons or icons you want and take off which ones you want
The click on close when your done
Nov 04, 2012 | Computers & Internet
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Remove the drop down icon bar on sony vaio
Usually, with a dropdown toolbar, you can put the cursor all the way to the top of the screen and with the toolbar visible, right click on it to activate a control menu from which you can stop it from dropping down, unlock it and move it to either sidr, or even turn it off altogether.
If this doesn't work, try entering yout laptop model name in Google search followed by "disable dropdown toolbar" for blogs and forums for your laptop model that may have a specific command or trick for your machine.
Good Luck
Jul 27, 2010 | Sony VAIO VGN-CS260J/P Laptop
How do i get speaker icon on my toolbar so i can adjust volume
guy click on start button move to control pannel it will display a dialog box for u,click properties it display a nw dialog box select level
May 02, 2010 | Microsoft Windows Vista Home Premium...
How to put program type on tool bar
  1. Adding Icons to the Task Bar
    1. Click on the Start Menu to open it
    2. Click on "Programs" and find the program for which you want to create an icon
    3. Move your mouse pointer to the program you want to use
    4. Depress and hold down the right mouse button while you drag the icon to the Quick Launch toolbar section of the Task Bar
    5. When you release the right mouse button, a short menu will appear
    6. Choose "Create Shortcut(s) Here." An icon will be created in the Quick Launch toolbar on the Taskbar
  2. Deleting Icons from the Task Bar
    1. Move the mouse pointer to the icon you want to delete
    2. Right-click on the icon
    3. Choose "Delete" from the short menu that appears. The icon has been deleted, but the program is still available to you on your hard disk
    NOTE: If you have carefully followed the steps above to add the icon to your Quick Launch toolbar, deleting it will NOT delete the program from your computer, it will simply remove the icon from your toolbar. The program will still be available to you.
Also you can "Drag" the program, to the bar, and "Drop" it on it. Check out a freeware application called StartupCPL at This places a Startup icon in your Control Panel which, when opened, lists all applications on your PC with a check box for each one. Simply put a check mark in each application you want to open minimized on startup. By the way, it states it is for Windows ME and 2000, but I have had it on XP for quite a while and it works fine.
Mar 01, 2010 | HP Pavilion dv6000z Notebook
How to install back the recycle bin icon how to erase download files in recycle bin
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box.
  4. Click Yes when you receive the warning message, and then click OK to close the Folder Options dialog box.
  5. Click Folders on the toolbar.
    Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons.
  6. In the left navigation pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop.
  7. On the Tools menu, click Folder Options.
  8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.
Feb 26, 2010 | Computers & Internet
How do i input my product key i have recieved a new product key from microsoft how do i put it into my system
Hello and thank you for using Fixya's services.
Go to the start menu, all programs and find activate license (it will be a set of key icons and may be also found near the clock on the bottom toolbar). Open this and hit, activate over phone. Choose, change product key and it will allow you to enter the new key. Once done, click activate.
Hope this helps!
Nov 19, 2009 | Microsoft Windows XP Home Edition
I somehow delted the icon for my internet browser
Hi. To get your browser icon back, (probably it's been hidden) you only need to go to your main menu, press the menu button again, and you should see the "Show All" option, select it and now you'll see the hidden icons in grey color. When you come over the hidden icons and press menu button, you can select to hide or show them. And when you do the "Show All" steps again and select it again, this time you'll hide your icons selected as hidden. Hope this helps.
May 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a gateway laptop with vista I purchased just recently. Somehow when I was using it, all of the start menu icons and software icons that were originally located across the bottom of my pc screen, are...
Using your toolbar preferences you can move them back to the bottom and then click the lock taskbar option to prevent this from happening again. You can access this by right mouse clicking on the taskbar then select properties. Hope this helps.
Dec 21, 2008 | Computers & Internet
Firefox bookmarks toolbar menu disappeared
In delicious menu there's a hide and show bookmarks menu
John Lanz (jquery rotating menu)
Oct 19, 2008 | Computers & Internet
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
235 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
