Question about Kicker IX704 Car Audio Amplifier
IX704 kicker HI my name is thordur and I have a problem with my amp IX704 when I turn the cd player on the amp takes its time to turn on but when it is turnd on it is okey, but if i turn the volum up it goes to red ( protection ) and turns off. but Then I just turn the volum down again and it turns on again.. So what do you think is the problem ??
    Novelist:
    Champion:
  • 218 Answers
There's a pretty good chance that your speaker load is too much or else your power coming in is not sufficiant. Be sure to check BOTH the battery and ground connections to be sure they are supplying enough power. If your speaker load is too much then correct that at once before you fry your amp. Good luck.
Posted on Jun 07, 2007
Can I install a Memphis kicker amp 1500 wat to a factory CD player in my 2001 Nissan Maxima
Sure if you have the speakers that take the "KICKING"! THe CD player merely provides the signal to the amp. As long as there is no backfeed of the power of the amp you should be OK.
Jan 02, 2013 | Car Audio & Video
When I turn up the volume the amp shuts off and displays an E-03
do you have your subs wired down to 1 ohm? The reviews on this amp is not very good, a lot of people said they had a lot of problems with this amp, a lot of blown fuses and cant take a 1 ohm load
May 12, 2010 | Kenwood KAC-X1R Car Audio Amplifier
My kicker zr240 powers up but its no sound coming out the amp the guts of the amp looks fine
it could be your input section on your amplifier were you rca jacks go in but you should check and make sure it aint your cd player out put on your rca jacks the easy way to check this is with a meter and a cd playing in your cd player turn your meter on volts usually your out put on rca 2.5v some cd players put out 5v so take your postive tester needle and stick it in the inside part of your rca jack and take negative tester needle and touch the outerside of the rca jacks and see if you get any reading if do that good on that part but on your amp no it could be in the input section of your amp it could be as simple as a burnt trace wire on the bottom circuit board or a op amp chip theirs alot in a amplifier but you can test them with a meter to find out witch one bad but i would take it to some one that work on amplifiers if you dont know how to test them
Oct 31, 2009 | Kicker ZR240 Car Audio Amplifier
Kicker IX704 amp fuse blowing problem
Hiya, sorry to say it could be anything from the flyback diode at beginning to output devices at end of circuit and guessing would lead to a whole lotta frustration. you going to have to find someone who at least has some experience to test with a meter etc to locate the fault (but it is more likely to be one those, (protection diode or outputs). Anyone in the area with electronic experience should/may be able to assist there.
Jul 26, 2009 | Car Audio & Video
Well i have a alpine deck with sub control and with or without epicenter ( audio control ) you can still here the voice coming out of woofers. 2 12inch. l7`s dual 4ohm. i had 1 a few yrs. back and i...
no u turn it completely off you don't use your hi or low pass at all turn it off. Also unhook the rca's and then do the entire reset by taking out the negative battery cable then replacing it and then plug ur rca's back in again. sometimes the amp gets confused on what kind of signal it needs to put out and I have only seen this with kicker amps the last one was with a kx150.2 and it wouldn't stop doin it til we unhooked the batt. and then checked on the back of the cd player and the rca's were in the speaker out's which is fine if ur just running components but ur not and neither was my buddy.
May 15, 2009 | Kicker XS50 Car Audio Amplifier
My amp turns off when i turn my speakers up
there is a safety feauture in the amp that shuts if off it is getting to much power from cd player outputs. all amps have this. some cd players also have this. unfortunately there is no way to get around this besides turning up the amp and turning down cd player
Mar 31, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
KICKER IX 704
Are you sure the resistors are on the output transistors (likely TIP35C/36C)?
If they're on the outputs, use the other channels as a reference.
Or are they on the power supply FETs (likely IRFZ44s)?
Jul 24, 2008 | Kicker IX704 Car Audio Amplifier
Amp protection
Does it go into protect if you disconnect the speaker wires from the speaker terminals of the amp?
Feb 16, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
IX704
you need an ignition noise filter available at radio shack. This electrical filter blocks "engine noise" to reaching your audio amp.
Jun 11, 2007 | Kicker IX704 Car Audio Amplifier
Kicker IX704 Car Audio Amplifier Logo
61 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
