Question about SanDisk Electronics - Others
When i plug flash disk it says u must format before you using it
  • SanDisk Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
If now you can see your usb drive there might not be any need to do the following
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
Hope this helps.
Posted on Nov 29, 2012
How do I use a flash drive?
Plug it in to the USB port on your computer. Use a Disk Formatting program to re format & test the drive. Find the mounted drive. Drag a file to it & drop
Sep 10, 2014 | PNY V165w Flash Drive 16 Gb
Format fat32 64gb
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system.
You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting.
You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory
http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html
Format USB flash drives with FAT, FAT32, or NTFS partition types.
Plug the Flash drive into a USB port on the Mac.
Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder.
Double-click the "Utilities" folder.
Scroll down to the Disk Utility program.
Double-click on the Disk Utility program to launch it.
Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen.
Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen.
Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name."
Click the "Erase" button at the lower right corner of the Disk Utility program's main screen.
Click the "Erase" button in the pop-up confirmation window that appears.
Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right.
Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program.
Remove the Flash drive from the USB port of the Mac.
Format Flash Drive in FAT on a PC
Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer."
Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage."
Select "Format" from the pop-up menu.
Select "FAT32" from the "File System" drop-down menu in the window that appears.
Click the "Start" button at the bottom of the window.
Click the "OK" button in the confirmation pop-up window that appears.
Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears.
Right-click on the icon of the Flash drive that is on the desktop.
Select "Erase" from the pop-up menu.
Remove the Flash drive from the USB port of the PC.
Sep 15, 2013 | Transcend Electronics - Others
Computer cannot access hp v165w
Sounds like you corrupted the MFT (master file table) on the flash drive. Format the flash drive and start over. You could also try something like GetDataBack after you flash the drive to recovery your data.
Dec 18, 2012 | Computers & Internet
Convert usb raw drive to fat drive
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system. You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting. You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory b> http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html Format USB flash drives with FAT, FAT32, or NTFS partition types. Plug the Flash drive into a USB port on the Mac. Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder. Double-click the "Utilities" folder. Scroll down to the Disk Utility program. Double-click on the Disk Utility program to launch it. Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen. Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen. Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name." Click the "Erase" button at the lower right corner of the Disk Utility program's main screen. Click the "Erase" button in the pop-up confirmation window that appears. Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right. Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program. Remove the Flash drive from the USB port of the Mac. b> Format Flash Drive in FAT on a PC b> Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer." Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage." Select "Format" from the pop-up menu. Select "FAT32" from the "File System" drop-down menu in the window that appears. Click the "Start" button at the bottom of the window. Click the "OK" button in the confirmation pop-up window that appears. Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears. Right-click on the icon of the Flash drive that is on the desktop. Select "Erase" from the pop-up menu. Remove the Flash drive from the USB port of the PC. Hope this helps.
b>
Dec 07, 2012 | Corsair Memory Computers & Internet
My micro Sd card will not format on my computer. I recently plugged it into my pantech matrix and copied some videos onto it. But after i plugged it into my computer, it will not format. Help...
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format Sd card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 26, 2010 | Sony Electronics - Others
Pen drive insert disk problem
2. Format
Jan 21, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have transcend 2 gb pen drive. but when i plug in it it is detected by system but while opening ''please insert disk into drive j:''
2. Format
Dec 07, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I want to format it
Plug your flash disk to the usb port of your computer. Wait for the system to detect it. Now go to windows explorer by right clicking the windows start button on your computer and choose Explore. Under My Computer, look for the drive letter associated to your flash disk (this could be drive E or F). Right click on the drive and choose Format >> Quick Format.
Hope this helps.
Oct 16, 2009 | Electronics - Others
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Flash Disk
Insert new disk for drive F:
and press ENTER when ready...
The type of the file system is RAW.
Please use the /FS switch to specify the file system
you wish to use on this volume.
Apr 03, 2008 | Dell Inspiron 6400 Notebook
Electronics - Others Logo
26 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
