Question about Tools & Hardware - Others
How to remove base plate from metabo orbital sander Sr211
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Metabo sr358 plate removal
Are you removing the plate from the top (4screws) or trying from the bottom. It appears that the eccentric is a loose press fit. I am looking at a breakdown but it is not really all that clear. I would suggest going to Metabotools.com and under downloads type in your model number which is 600358-42, the 6 is already in place so what I did is add a 1 to the end of it and found the tool. Let me know but did you also check the clamps for the reason. Usually the platen is sold as an assembly.
Posted on Jan 10, 2009
Information on replacing the four rubber bushings mounting to the base plate
Hi Kirk
Have you tried the Manufacturers site..
Doubt if any of our guys go that deep
Nov 29, 2015 | Clarke OBS-18 Orbital Sander with Dust...
Sander doesn't spin
YOUR BALLBEARING where the disk is on mounted is the right bearing that have the problem for shure it is full of dust or completely dry it will not turn anymore SIMPLY TO CONTROL IF YOU MOVE YOUR DISK NOW ON YOUR MACHINE YOUR ARMATURE TURNS DIRECTLY WITH THE DISK thats not good the armature must stand still , replace the ballbearing or remove it and open it with a very little sharp screwdriver on the both sides solvent it out try to turn the bearing carefully until its turns without problems dry it or blow it out with a compressor and if its dry lubricate with ballbearing grease close it again and mount it again
Nov 13, 2013 | Metabo SXE450 00458 6'' Random Orbit...
Base plate has come off from the main part
pos 7 315416210 eccenter 1 x
pos 2 141180710 a ring 1x
pos 8 143193270 o-ring 1x
pos 9 316026510 carrier complete 1x
Mar 26, 2013 | Metabo SXE 450 TurboTec 6 Inch Dual Random...
Metabo paper disc Bestell-Nr-24 026 Metabo SX E 450 cling-fix sanding discs
j kjh kuyiyut khjkhkhjkgghjkghkghkjhkjhgkjhkjghkjhkghjkghjkghjkghjkkmnn,m,mn,jgkkjlkjljkliuhfgdvvvjjkjkhjkcnvbxn,mn,mnc,mxbn,mbn,vcnb,vcnxb,mnkjfkjdshfjkdsfhjsdbnmbhjmsgdifgiueryfuugadf hgadfhjdfghfdgshjgjhsdgjfgsdjhgfjhczmbmnzxcbnmgfhjga shfd
Feb 01, 2011 | Metabo 600129420 SXE450 TurboTec 6" Dual...
Dewalt d26451 type 1 random orbital sander. why does this sander jump around on the material and feel like it's fighting me all the time instead of sanding smooth and easy?
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Aug 10, 2010 | Dewalt Heavy - Duty 5" Random Orbit Sander...
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Makita random orbit 5". The pad flew apart. Is it replaceable ?
Usually there are 3 screws holding the plate to the eccentric assembly. The pad is formed to a metal plate and is sold as an assembly. You can go to Makitausa.com with the model number and get a replacement pad.
Feb 07, 2009 | Makita 5" Random Orbit Sander
Jan 10, 2009 | Metabo Tools & Hardware - Others
Tools & Hardware - Others Logo
66 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
