Error 15 file not found in black screen after pressing any key then show the windows with loader in red screen . how to start my laptop normally?
  • 277 Answers
SOURCE: Pressed FN key simultaneously with F5 Key and screen black
try to press again fn+f5 key
Posted on Apr 05, 2008
masteria
  • 355 Answers
SOURCE: Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
Posted on May 09, 2009
foxyreign
  • 52 Answers
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Posted on Jun 10, 2009
KingDWS
  • 1606 Answers
SOURCE: dell inspiron 1420 startup error
You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
Posted on Jul 09, 2009
ArgusFixer
  • 51 Answers
SOURCE: DELL INSPIRON 1525 NOTEBOOK :
This sounds like the dreaded Windows Vista Black Screen of Death (KSOD). you might have a bad hard drive, but even more likely some software or a driver is causing a problem and caused Vista to get stuck. The repair will not work. You might be able to run a complete repair from the Windows Vista CD, if you have one. If you are not too experienced, take it to a reputable computer service center. If you are at all technical and have time, google your problem and you will see thousands of similar users with same problems.
This is one reason Microsoft released Windows 7 so soon.
Posted on Feb 17, 2010
When I turn on the laptop, the asus screen comes up and it seems to be booting but after a long while shows an error and restsrts never actually booting up
While it starts to boot up, press the ESC key, or appropriate key that allows you to enter into setup. From the setup area, look for an option to boot into safe mode or into a Command Prompt. Once in safe mode, if it works, press start, and go to run and enter CMD. In this window type in bootrec /fixmbr and press enter. Next type in bootrec /fixboot and press enter. Restart your computer normally.
If you can start in the command prompt, enter in the same commands.
Also if you have a windows recovery or windows installation disk you can access the command prompt as well as fix any issues that are cauing your machine to not boot.
Here is a step by step guide on how to solve such problems.
How to Manually Repair Windows 7 Boot Loader Problems
Apr 23, 2015 | ASUS Computers & Internet
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    Start up
    First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
    After that restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
    If you able to start in safe mode then update your graphic drivers from the manufacture site of your laptop
    Let me know if it helps you.
    Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
    Jul 04, 2013 | HP Pavilion DV2910US Laptop
    Black screen before login
    1- Try to start your laptop in safe mode, normally Pressing F8 key when windows starts up
    2- After that Update drivers for your hardware from the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop. Most black screen are hardware or driver related so updated drivers could fix the cause of the STOP error.
    3- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
    4- If this didn't help you then simply get the Intel software partner Reginout to fix all the errors which causing Black screen
    Jun 19, 2013 | Dell Latitude E4300 PC Notebook
    Get a blank screen
    go to save mode press f8 before windows start then press windows key + r then type temp remove all Files then type %temp% then remove all Files then restart
    Dec 11, 2012 | Toshiba Computers & Internet
    My dell inspiron 1525 has a black screen with a white cursor showing
    First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
    1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
    2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
    3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
    4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
    5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
    Dec 10, 2009 | Dell Inspiron 1525 Notebook
    Dell inspiron 1525 notebook will not start windows
    Jun 09, 2009 | Dell Inspiron 1525 Notebook
    Windows vista ultimate will not boot up
    Press enter and submit the changes :) computer should repair itself from a back up file and start as normal.
    Regards
    Jun 08, 2009 | Acer Aspire 3680 Laptop
    Booting 'Windows Vista' error, Please Help
    This is happening to me press F8 for advance setting try one of the 12 options it should work on a VAIO laptop or contact Sony
    Jan 12, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
    Hi I have Sony VAIO VGN NS135 laptop on which I have installed Windows Vista Ultimate Now there is error in booting and showing these lines Booting 'Windows Vista' acpi Vista Loader 2.1.2 Done! fallback 1...
    This means that the operating systems was not installed properly...."Boot manager is failed... and ntldr is the main file... which help computer to boot up..." try reinstalling the operating system again...
    Computers & Internet Logo
    42 people viewed this question
    David Payne
    David Payne
