Changhong split system/reverse cycle air conditioner error code E3
I dont know the exact model number or anything, i dont have any of the documentation, its a rental house. but one of the units has stopped working, and flashes an error code "E3" which i have no idea how to resolve because as i mentioned earlier, i dont have any of the paperwork/manuals relating to the unit. would anyone know what it is and how i could possibly rectify it instead of having to fork out to fix it or wait for the real estate to do so?
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
bobotfel
  • 236 Answers
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
SOURCE: Air Conditioner Error code?
E5 is a coil sensor problem,this can be caused if you have had dirty filters, damaged the coil sensor while cleaning it or a common problem on any air conditioners, ring the boys at ager on 33412663 as they are very helpfull and will rectify the problem staright away for you
Posted on May 06, 2009
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
I have a Frigidaire split system a/c with error code E1. What does this mean?
Hello friend, thank you for your post!
I understand that your Frigidaire split air conditioner is displaying an error code of E1 and you would like to know its meaning. In order to assist you further I would need to have the model number of your air conditioner. With that information I would be able to further assist you. -Matt
Apr 14, 2016 | Frigidaire Heating & Cooling
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
