Question about IBM Infoprint 40 Laser Printer
Infoprint 32 with 454 Fuser error - IBM Infoprint 40 Laser Printer
5 Suggested Answers
  • 123 Answers
SOURCE: Infoprint 40 with 454 Fuser error
Sure.. the 654 is an MCU communication error, so the MCU card is
probably bad (it's located near the front left side of the printer,
under the operator panel). If the MCU is good, the controller card is
the 2nd most likely suspect.
The least expensive way to fix the problem would be to purchase a used
Infoprint 21 with a bad fuser (one that is posting a 454 error), and
put your good fuser in that IP 21. Then make sure that the controller
card in your IP 21 is good by swapping it in the operational printer,
and sell the good controller card -- you might come out a few dollars
ahead in the end.
Posted on May 14, 2009
don_farr
  • 1018 Answers
SOURCE: Hi, I have an IBM Infoprint 1352 and it keeps
Okay, I need some additional information from you and I have a couple of suggestions for you.
First, is your printer plugged directly into a wall receptacle? If not, plug the printer cord into one.
A couple of other things could be going on. The fuser that was used may not be the correct fuser. This can cause the fuser sensor to report an error based on the wrong heat lamp inside the fuser.
The system board (motherboard) may be reporting the error incorrectly/ In which case the motherboard should be replaced.
The fuser sensor may be defective.
If the repair was completed by an IBM Certified technician, then there is a warranty period associated with the repair. Call your local IBM Office and ask for a service manager and issue a complaint on the repair activity.
IBM may in turn refer you to a TSS manager or choose to handle the complaint on its own. When I was a field tech for IBM, the goal was first time final, so I imagine that they will be very concern that the tech has been there twice and yet the failure is the same.
Good luck Don
Posted on Jul 15, 2009
  • 32 Answers
SOURCE: fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
Posted on Jul 24, 2009
brett207
  • 231 Answers
SOURCE: IBM Infoprint 1532 giving error code 922.14
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Posted on Feb 05, 2010
Infoprint 1572 code 923.01
The 923.01 error indicated an over temperature state in the fuser assembly caused by a failure in a part called a thermister. You will need to replace the fuser to clear the error. This is a user replaceable part, you only need a Phillips screwdriver to replace the fuser assembly. The part number you need is 39V2600 and they are available from places like amazon.com or Buy.com
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | IBM Infoprint 1572 Laser Printer
IBM Infoprint 1532 giving error code 922.14 -service fuser error
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
Hi, I have an IBM Infoprint 1352 and it keeps having a 925 fuser error, the Fuser and LVPS (low voltage power supply) have both been replaced and the error comes back within a day or less. Any ideas?
Good luck Don
Jul 15, 2009 | IBM Infoprint 1352 Laser Printer
Receiving an error 920.06 Service fuser error
920 .06 Fuser is not increasing in temperature even though the lamp has been on for an extended time. Fuser page count between 0 and 99,999. • Fuser is not receiving AC power. • Poor supply line voltage.
Jun 16, 2009 | IBM Infoprint 1532n Laser Printer
Infoprint 1634 repeatedly jams
It may be time to replace the Fuser.
There is no certified way to repair a Fuser with purchasable parts, the assembly it self must be replaced.
May 22, 2009 | IBM Infoprint 1634 Laser Printer
ahead in the end.
May 14, 2009 | IBM Infoprint 40 Laser Printer
It's either the (fuser) heater lamp, thermistor, or fuse..call for service.
Apr 28, 2009 | IBM Infoprint 1532n Laser Printer
922 Server fuser error
922 fuser errors is a bad fuser - you might try turning off printer - holding the select and return button down at the same time - turn on printer - HOLD buttons until it starts inting (about 15 sec) and the arrow over to print test pages - if the error doesn't return - repeat a few times.... this may by pass the error.. then power off - ON and see if problem is gone. replace fuser if not
Apr 08, 2009 | IBM Infoprint 1120 Laser Printer
Fuser error on my ibm infoprint color 1464
Apr 08, 2009 | IBM Infoprint 1116 Laser Printer
IBM Infoprint 40 Laser Printer Logo
35 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
