Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I bought a4g sandisk memory drive to plug into my USB slot on my DVD recorder. I synced Windows media player to the sandisk drive but when I plug it in it shows folders with no files...and I did format the usb drive. Help me please
  • SanDisk Master
  • 2,878 Answers
Check DVD recorder file types supported? Windows Media player likes WMA and WMV. DVD movies are AVI, MPG, or VOB. These are just examples.
Posted on Nov 29, 2012
SOURCE: Insignia mp3 player reads "Unable to format external memory!!"
I too had this same problem.
i downloaded and installed the firmware update...and now my 2gb microSD is readable.
link for download:
http://www.insignia-products.com/t-New%20Video%20Player%20Firmware.aspx
follow directions and you'll be good to go.
Posted on Nov 02, 2008
  • 7 Answers
SOURCE: computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Posted on Jun 12, 2009
bob_computer
  • 3153 Answers
SOURCE: SanDisk Usb Flash 8GB unable to format
TRY SOME OF THESE STEPS BEFORE YOU THROW IT
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 17, 2009
skipsinclair
  • 152 Answers
SOURCE: Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Posted on Oct 20, 2009
willell
  • 67 Answers
SOURCE: how do you reset the sandisk Cruzer Micro 4GB USB
go into my computer, rightclick the drive, click format, select ntfs or fat 32, give it a name, use quick format and click format again.
Posted on Jan 27, 2010
Testimonial: "Wow that was easier than I expected thank-you very much willell."
OK PEOPLE!! have asked this same question over and...am getting the run around...please don't make me continue asking for help with this question. its a sandisk mp3 mini clip, and this issue is getting any...
Use SanDisk MP3 Players
SanDisk is an electronic device manufacturer that creates various types of MP3 players under the SanDisk Sansa product line.
The SanDisk MP3 players range in storage capacity, starting at 512mb, and are intended to operate on the Windows operating system.
Most SanDisk MP3 players also include a built-in video player with a color screen, an FM radio tuner, and a memory flash card slot to expand the MP3 player's storage capacity.
Use SanDisk MP3 players to take your computer's MP3 library with you and listen to music wherever you go.
1. Verify that your computer meets the operating specifications required to sync the SanDisk MP3 player with the PC.
All SanDisk MP3 players require Windows XP or later; Windows Media Player; and a USB 1.0 port. A USB 2.0 is important if you want high-speed music syncing.
2, Check that the SanDisk MP3 player has a full battery charge.
All SanDisk MP3 players have a rechargeable lithium ion battery, and some SanDisk devices have a replaceable battery.
The battery icon on the top right-hand side of the SanDisk MP3 player's screen displays the current status of the battery's charge.
If the battery is low, recharge it before using the SanDisk player for the first time.
To charge, connect the player to your computer's powered USB port using the included USB cable.
The SanDisk player's screen will display a yellow charging icon.
Unplug when charging is complete.
3. To turn on the SanDisk MP3 player for the first time, unlock the "hold" switch on the top of the MP3 player by sliding it so that the orange tab does not appear.
Then, press the "power button" once.
Wait for the SanDisk MP3 player to respond.
The thumbweel of the player will flash a light and the screen will turn on to display the player's menu options.
Turn off the SanDisk player by holding down the player's power button for two seconds.
Wait for the screen to display "Goodbye" before releasing the button.
4. Practice resetting the SanDisk MP3 player to solve critical software errors and to fix the MP3 player if it freezes.
To reset the player, hold down the power button for fifteen seconds.
This resets the MP3 player to its original factory settings and can help resolve any problems you encounter while using the SanDisk MP3 player.
5. Connect the SanDisk MP3 player to your computer using the included USB cable.
Once the computer has sensed the connected device, the SanDisk player's screen will display "Connected" and the SanDisk Portable Media Player will be listed under Other in your computer's My Computer window.
6. Add music to the SanDisk MP3 player.
Double-click the Portable Media Player listed in the My Computer window.
Double-click the Music folder.
Select the MP3 files that you wish to load onto the MP3 player and drag them into the Music folder.
The player will load them into its internal memory and make them available for playback once the device is disconnected from the computer.
7. Sync your MP3 song playlists from Windows Media Player to the SanDisk MP3 player.
Create a playlist in Windows Media Player and connect the SanDisk MP3 player to your computer (see Step 5).
Once its connected, Windows will display a dialog box. In the box, click "Sync digital media files to this device."
In the next window, click Set Up Sync. In the menu, click Personal Playlists and then select the playlists that you wish to transfer to the SanDisk player.
Click the Add button then push the Finish button to transfer your Windows Media Player playlists to the MP3 player.
Aug 09, 2013 | SanDisk Clip Audio Players & Recorders
Sync itunes
Launch iTunes.
Connect your media player with SanDisk memory card installed to your computer through its USB adapter.
Wait for the player's device icon to appear in the iTunes Source pane.
Drag and drop music titles from the library pane directly onto the device icon.
The music will sync onto the player's SD storage.
hope this helps
Sep 17, 2012 | SanDisk Cruzer Glide - USB flash drive -...
I have songs on a usb and I want to put these songs onto my windows media player library
plug in usb drive....open window media player...let it 'search' computer for music/media files...it will automatically add them to your library
Oct 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
MY lap top does not have a cd drive and i need to get a download for the sansa clip. so that i can put music on it off of my laptop
No extra software is needed if you are running XP or Vista. Just plug the player into an empty usb port and wait for windows to recognize it. Then you can drag and drop your music into the music folder under the internal memory of the player or you can sync it through Windows Media Player.
Apr 29, 2009 | SanDisk Sansa Clip MP3 Player
Disable music auto refresh
Disable auto-sync in Windows Media Player and it will stop doing this.
-Tha Mp3 Doctor
Dec 05, 2008 | SanDisk Sansa Clip MP3 Player
Sync
Inorder to sync the player just simply plug in the usb cable to the bottom, open up the drive that mounts as a result. Then simply drop the songs into the main window and then go to bottom of windows and tell it to unmount and your system will automaticly pick it up.
Jul 10, 2008 | SanDisk Sansa m240 MP3 Player
I bought Sandisk Sansa c250 2GB MP3 Player, On the fly FM and voice recording, MicroSD slot -Recertified - Sansa c200 online. they have not given me any CD. where to find software upload songs into this
You don't actually need any software, you can sync it thru itunes or windows media player, please visit my blog and view the article on getting music onto a mp3 player without software.
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Audio Players & Recorders
Sandisk Sans e250 player stop working
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Its not plug and playing Sandisk 240m 1g
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Jun 07, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
119 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
