Question about Brother CE8080PRW Limited Edition Project Runway Sewing Machine
Bobbin thread will not catch
Used the button foot and ever since it will not catch bobbin thread
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
Zenqi
  • 208 Answers
SOURCE: Bobbit thread on my Singer Stylist 457 will not catch
Pull the slide plate open and watch the hook (the rotating part under the bobbin case). It should move around with no hitch.
If it does not turn, it has a broken gear. The model 457 has a vertical shaft gear that breaks and it's easy to replace.
Posted on Jun 19, 2009
SOURCE: Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
Posted on Jun 21, 2009
yeroc
  • 397 Answers
SOURCE: bobbin thread won't catch after changing needle in stylist 457. also what tool to use to change needle in serger
machine needs to be timed,,usually a 30-50 repair, could try dropping a needle just a tad bit to see if it catches
Posted on Nov 28, 2009
Thread suddenly jams , bobbin won't turn,after cleaning, re-threading etc makes one stitch with wheel turn then jams again.
Besides installing a brand new needle (which you've already done), unthread the top thread. (Cut the thread below the spool, raise the presser foot, and pull the thread DOWN from the thread tail end--NEVER PULL thread UP!)
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point and then tweak it so both threads meet in the middle of the fabric.
Jun 24, 2017 | Sewing Machines
Most of the time the bobbin stitch is correct. Occasionally there is a loop in the bobbin thread. Any suggestions as to what this could be?
Is it actually the bobbin thread that loops or is the loop appearing on the underside of the fabric as you stitch? If it is a loop under the fabric, that's usually an indication it is an upper thread issue. Thread irregularities that appear on the topside of the fabric are generally bobbin related.
First thing to try is installing a brand new needle. Verify it is the correct needle for the fabric and thread being used.
All About Needles
Sometimes, the fabric being stitched will "grab" the thread and hold it for a second before releasing and will cause a loop. In this case, a needle with a larger scarf and eye may be helpful.
You might also open the upper tension as much as possible, RAISE the presser foot and run a piece of UNwaxed dental floss through the tension disk a few times to clear out any gunk that may be stuck there. A piece of pearl cotton dipped in rubbing alcohol and squeezed moist/dry will also work.
Remove the upper thread. RAISE the presser foot and rethread the top thread from the beginning. Use only fresh, good quality thread--NO old or bargain bin variety! Try using the same thread in the top and bobbin. Make sure the thread is firmly seated in the tension disk and the thread path is correct. Check that there are no burrs or snags in the thread path that could be catching the upper thread. Especially, check that the thread is not catching on the spool "slit" that holds the thread when in storage. Every time the thread navigates around the thread spool, it could be catching on that slit just enough to cause a loop.
Try changing the bobbin. There could be something amiss with the current bobbin--could be nicked or could even be the wrong bobbin for the machine. Also, make sure the bobbin is loaded and turning the correct direction in the machine.
Set the upper tension to the midway point. This is usually the starting point, although it will probably require some tweaking. Test your stitch and adjust the tension so the upper and bobbin threads meet in the middle of the fabric. Neither thread should dominate one side of the fabric or the other.
Understanding Thread Tension Threads
Last thing to try is a different presser foot.
If you still have the intermittent loop, you might want to take it for service. Could be a problem within the tension disk.
Nov 05, 2016 | Sewing Machines
Won't catch the bobbin thread everytime. skips. I have retreaded everything several times, reajusted tension, and even the presser foot tension.
Install a brand new needle.
Check the upper tension: Remove the thread. RAISE the presser foot and rethread from the beginning. This ensures the thread is seated properly in the tension disk. Make sure the bobbin case is threaded properly.
If still missing the bobbin thread, it probably has a needle/hook timing issue.
Feb 10, 2016 | Sewing Machines
Model w388 how to catch bobbin thread
After changing bobbin, hand crank the machine a couple of revolutions and look carefully below the foot to see if thread has caught the bobbin thread. Use flat scissors or ruler to slide under needle and foot and slide sideways. THat will catch it!
Feb 17, 2015 | Sewing Machines
How do I put cotton on machine
Paul... youtube it.... It's really not difficult. Have to load bobbin with thread first... install bobbin (under the needle plate in its holder) thread cotton from top of machine through the correct catch points to the needle.... catch the thread from the bobbin..... pull threads under pressure foot (but look in youtube... loads of vids)
May 16, 2014 | Janome Sewing Machines
The upper thread will not pick up the bobbin thread
You should do this by putting very slight pressure on the foot control (or turning the wheel by hand) with the machine's pressure foot up. Then pull the threads by hand to the back of the machine. If the upper thread does not catch the lower thread then the bobbin is not correctly threaded in the bobbin case.
Oct 16, 2013 | White Sewing Sewing Machines
I have a brother sewing machine. i threaded and have rethreaded and threaded the bobbin over and over. it will not move the fabric and botton thread will not catch onto top. what am i doing wrong?
Brother machines are usually a very good brand. Sounds like you are having a small problem with threading..........I know how frustrating that can be!
Start over....totally from the beginning. First, clean the machine of all dust, I use a small paint brush to remove lint from the bobbin case area. Oil the machine. Remove all the thread from the machine, use a different bobbin and rewind it with new thread. Make sure the bobbin thread is the same as the thread you use to thread the upper needle with. Use a new needle that is the appropriate size for your sewing project. Check to make sure the feed dog is moving when you turn the wheel that raises the needle up and down. New needle, new bobbin, new thread......before you place the fabric under the presser foot (and with the presser foot raised), turn the wheel one complete rotation to allow the upper needle thread to catch the bobbin thread. Gently pull both threads out towards the back of the machine, making sure the bobbin thread is now coming up through the little hole in the feed dog plate. Place fabric under the presser foot, lower presser foot and as you slowly start to sew, make sure you have the bobbin thread pulled with slight tension out from the back of the needle. This will take up any slack in the bobbin thread and keep it from making a knotted mess. Good luck, I hope this helps.
Feb 13, 2011 | Sewing Machines
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Hd-110 can't pull up the bobbin thread
If the needle will not catch the bobbin thread, try replacing the needle and make sure the flat side of the needle shaft is facing the back of the machine.
Always thread a sewing machine with the presser foot up.
Lower and raise the threaded needle, while holding onto the end of the thread. This will pull up the bobbin thread.
Take both thread ends under the presser foot and to the back of the sewing machine.
Hand Walk the needle a couple of stitches before using the power pedal.
Mar 19, 2010 | Singer HD-110 Mechanical Sewing Machine
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother CE8080PRW Limited Edition Project Runway Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
