Question about Kenmore Sewing Machines
Need a manual for sears kenmore sewing machine 158-1305
Need to know its operations and where to oil it
SOURCE: kenmore Sewing Machine
www.mastersewusa.com has free kenmore manuals
Posted on Feb 17, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Posted on Apr 02, 2009
SOURCE: 1964 sears suburban 725 riding tractor model # 917.60634 manual. Sears Kenmore vintage sewing machine manual model# 148.12071.
go to www.sears.pammar.net for a few bucks he will send you the manual in a pdf. format
newbeginning1983@yahoo.com
Posted on Apr 04, 2009
I need operating manual for Kenmore sewing machine model no 158-17740
Search for:
Make Model manual
Sears carries a lot of manuals for Kenmore--sometimes for free...
Feb 22, 2018 | Kenmore Sewing Machines
I need a manual for a Kenmore sewing machine model # 158.12410
Sears carries manuals for most Kenmore machines. Even if they may not have your exact model, machines operate much the same, so a manual for a similar model would be helpful.
FWIW, my first sewing machine was a model similar to yours. A real keeper--wish I would have kept mine. However, your machine, being mechanical, does require frequent cleaning and oiling. These good old machines are often forgotten, but it would be well worth your time to give it some TLC to keep it running smoothly.
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Nov 11, 2017 | Kenmore Sewing Machines
Should I oil the motor on a kenmore sewing machine model 158.905?
Do NOT oil the motor unless the manual instructs you to do so. (Sears carries manuals for most of their machines.)
Your machine appears to be an older mechanical machine. As such, oiling would be necessary for the moving metal parts. The following may be helpful to keep your mechanical machine happily operating. (Although the following is for machines that have seized due to lack of oil, following the procedure is helpful in preventing the machine from seizing.)
Wheel on right side that controls the needle up and down is very tight...
May 06, 2017 | Kenmore Sewing Machines
I need the oil diagram for a kenmore sewing machine 158.19310
have sears kenmore sewing machine model 148 13100 where is oil needed
This was the first new machine I purchased new. Being mechanical, it needs frequent cleaning and oiling to keep it running smoothly.
Jan 05, 2017 | Kenmore Sewing Machines
Where do I oil Kenmore Model No 385 16221 can't find it in the manual
Page 94 of the manual:
Kenmore 385 16221 Owner Manual Table Of Contents
FWIW, it is important to keep your machine clean and oiled for it to operate properly. Use ONLY good quality sewing machine oil and apply ONLY 1-2 drops every place indicated, approximately every 40 hours of sewing time.
Dec 23, 2016 | Kenmore Sewing Machines
I can't seem to find a free manual for my Kenmore 385 17926090 sewing machine. does anyone know where i can download one please? thank you in advance
Sears carries Kenmore manuals, but they are not free. Although, probably a worthwhile purchase considering the information you would have access to.
Sep 06, 2016 | Kenmore Sewing Machines
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
Model #158 12290
http://www.tias.com/173/PictPage/3924074944.html Sorry, Sears doesn't seem to have a free copy of the manual. But Linda at Relics is a very reputable manual supplier.
Feb 05, 2014 | Kenmore Sewing Machines
Where are the oiling points on this model??
Ok, googled "sewing machine 385 12914" and it brought up Kenmore.... you can get most of their manuals through the sears website. But I did not find 385 12914.... here is a 385. 12714 set of manuals on this page including a service manual. Perhaps they are close to your model?
http://www.searspartsdirect.com/partsdirect/user-manuals/38512714090-Kenmore-SEWING+MACHINE-manual
Aug 31, 2012 | Sewing Machines
I need a FREE manual for a sears kenmore 2142,model 158.331. i need to know where to oil it and thread it.
Unlikely you will get a free manual but try this site for manuals www.sewing-machine-manuals.com and click on relics, don't be put off by relics
Nov 02, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
