MyPIXMAMP210 won't pick up the paper in the printer. I have worked on it for hours and can't make it work. Each time the machine grabs the paper on the right corner and twists the paper and of course it stops. It always says E2 but I don't know what else to do. Help....Should I just haul the thing back to Best Buy?
  • laurabfergus Jan 10, 2009
    The printer still doesn't pick up the paper. I need to quit for the day. Thanks for your help, they were ideas I never thought about doing. I appreciate the prompt attention to this problem. I couldn't have hoped for quicker service.
  • 1,031 Answers
Load paper correctly then press Black or Color button (MP210)
  1. Remove paper from the rear tray.
  2. Open the paper output tray and extension. below.then Set the paper thickness lever according to the media being used. Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    see figure here http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15402
Posted on Jan 10, 2009
    Genius:
  • 1,689 Answers
Thank you for using fixya. The culprit in this matter is the printer rollers or the friction pads. On both sides of the paper feed you should see that mechanism, usually placed on rollers where the paper is fed. There is a possibility that it is broken or not aligned. You can have these parts replaced but if it is still in the warranty period, it is strongly suggested that you haul it back to Best Buy before doing any physical troubleshooting with the unit.
  • 19,396 Answers
That is because one of the two rollers is stuck or is not picking the paper.
Try playing with the rollers that pick up the paper.
Try also looking for foreign objects in the printer paper feeding path.
Turn the printer upside down and shake it gently to find out if there are foreign objects inside.
    Sergeant:
  • 431 Answers
Check the paper roller first
  • nematics
    nematics Jan 10, 2009
    the paper rolling gear inside has been malfunctioned or dur to weakness in motor
Align PIckup Roller Gears HP Officejet 4500
Reset the product:
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 6 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
If it does not resolve then service the product
Jun 21, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
HP Officejet 8500 won't load paper
check paper pickup rollers, check paper picking up unit weather its trying to grabbing the paper.If pickup unit not trying to grab its major mechanical issue..
Jul 11, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
PAPER NOT RECIVE
Paper not picking up?..shoot print command and observe printer trying to grabbing the paper?..see any marks on paper leading edge? Remove cartridge and see inside paper pick up roller,might be its dusty or warn out, remove the pick up roller releasing the side locks, clean with wet cloth, fix it back then try once, if its success..end the process.. if not replace pick up roller..observe similar kind of machine: 2_4_2012_9_32_43_am.gif2_4_2012_9_33_08_am.jpg
Feb 04, 2012 | HP LaserJet M1005 Printer
While this machine worked fine for about 9 months, it now grabs 8 or 10 sheets of paper at a time. I can't find any kind of paper thickness adjustment, either on the machine or in the documentation. Any...
You might see if you can locate the rollers which pick up the paper and clean them with a soft, lint-free cloth and plain water. They get worn smooth and after a while won't pick up the paper properly, just like ink-jet printer.s
Oct 14, 2009 | Samsung CLP 315 Laser Printer
My L7580 grabs too many pieces of paper. Instead of one sheet it grabs 4
Time to replace the paper pick rollers located in/near the tray and above on the pick-arm or paper path
May 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Hi my printer doesn't pull paper from tray1 even if it set to pull paper automatically from tray 1 and 2 inadditon to this it needs manuallly feed papers.
My HP OfficeJet 7310 behaved correctly on the automatice paper feed for a long time and then began to be unable to pick up the page or would grab 2 or 3 pages at once. I was about to spend the $$$ to replace it, maybe $400 at that time. Instead I watched it work again and angin or not work. Noice the 1 inch square piece of cork? I went to Hobby Lobby and for less than $2 bought a roll of very thin cork. I cut an inch square and replaced the one on the machine and it has worked perfectly since. I still have 99% of the cork roll. What it?
Jan 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Will not pick up paper
Take a wet cloth and clean the front grabbing roller by rotating roller on the wet cloth. You may have to do several times and after printer has not been used for a while.
Dec 10, 2008 | Kodak Easyshare Printer G600 Thermo...
C1100 mp error
The MP E error relates to the registration assy on the rear of the machine. There are 22 possible causes of this error. I suggest you get a service manual for the machine and work throught the easier checks one by one. You can get a manual from http://www.TheServiceManualShop.com or http://mikeburton.tradebit.com/
Jun 11, 2007 | Epson Aculaser C1100 Printer
15 people viewed this question
jasbo
jasbo
