Question about Maytag PAV2300 Top Load Washer
Washer noise maytag pav2300 popping sound and wont spin
  • Jack Iaria
    Jack Iaria May 11, 2010
    Please describe the popping sound in more detail!
    Does it sound electrical or mechanical?
    If it's electrical don't use it until it's fixed or you may burn out the motor!
    Does it wash?
    May be a belt!
  • Maytag Master
  • 8,220 Answers
Bad pump. Tip the machine back and remove the belt. Turn the pump by hand and check if it is locked up.
Posted on Jan 21, 2009
My Maytag PAV2300 Top Load Washer is nine years old. It just started making this LOUD grinding noise when it's washing, rinsing and spinning. What could it be?
I have the same type washer and it is about the same age makes the same grinding noise as the above mentioned one. Did this person ever find a solution?
Aug 31, 2010 | Maytag PAV2300 Top Load Washer
The motor is making a loud vibrating noise
Maytag PAV2300 top load making very loud squeeking noise when set at spin
Jul 09, 2010 | Maytag PAV2300 Top Load Washer
Washer wont spin. Makes a humming noise and a burning smell
your belt needs changed. and i would check the pump to make sure its not siezed
Dec 11, 2009 | Maytag PAV2300 Top Load Washer
Maytag Washer model #PAV2360AWW
It is not the trany it sounds like you need to get your tub seal and bearing kit installed.The trany is fine it can get costly if you get a person who does not know how to fix properly good luck:)
May 04, 2009 | Maytag PAV2300 Top Load Washer
Washer wont spin
CHECK THE MOTOR COUPLING. IT MAY BE THAT. CALL YOUR REPAIRMAN AND SEE IF HE CAN FIX THE PROBLEM. IF NOT, THEN YOU NEED TO BUY A NEW WASHER. GOOD LUCK.
RODNEY
Apr 08, 2009 | Maytag PAV2300 Top Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
