Question about Maytag Dishwashers
Maytag jetclean mdc4100awx - Maytag Dishwashers
3 Suggested Answers
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Posted on Jul 15, 2009
  • 457 Answers
SOURCE: I have a Maytag Jetclean and it doesn't rinse well
normally is you are completly filling rinse aid compartment. and the dunit is not dispensing the rinse aid you must replace dispenser. let me know if this info was helpful
Posted on Feb 27, 2010
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
In a cold weather my dishwasher wont drain
this manual should help:
http://www.manualslib.com/m/maytag+mdb5600a+jetclean+ii.html\
Feb 17, 2015 | Maytag 24 in. MDB5600A Jetclean II...
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Washer won't start
On the Maytag Jetclean II, this problem can be fixed by replacing the timer assembly that is behind the rotary knob you mention.
Good Luck!
Mar 20, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
29 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
