Question about HP Office Equipment & Supplies
Setup i se where the input paper tray is .But where is the output paper tray when printing muliple pages from the computer.I am beginning to set up a HP hotosmartC4480
    Novelist:
  • 180 Answers
Fear not! I have a Photosmart as well. When you pull down the door in front, you'll see a bar that you can pull out. At the end of that bar is a little tab you can pull up. This guide bar catches the paper tht comes out and that little tab will prevent it from falling off!. Excellent choice in printers.
Please rate this tip accordingly and thanks for using Fixya.com. Keep us in mind in the future for your needs.
Posted on Jan 10, 2009
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
When I send something to print the right hand side of the paper comes out all crumpled up, as if there is something stuck that it can not pass. I have looked in the printer but can't see anything. When...
Issue
While printing, the printer paper is torn, ripped, wrinkled, or damaged.Solution Follow these steps in the order presented to resolve the issue.Step one: Remove all paper from the input and output trays Remove all paper from the input and output trays on the product.Step Two: Check the paper path for obstructions Press the Power ( ) button to turn off the product. Verify the input tray is empty, and then check for paper jams, bits of paper, and other obstructions, gently removing any obstructions.Lift the top door or the front cover, depending on the product, to access the print carriage, and then check for any obstructions in the paper path.Gently remove any paper or other obstructions from the paper path you might find, and then close the print carriage access door.Open the rear access door.Gently remove any paper or other obstructions from the paper path.Check the spring-loaded rear access door rollers to verify that they are clean and can be rolled.check the paper rollers inside the rear access and verify that the rollers are clean and roll upwards.Check the star wheel assembly inside the printer on the output side of the carriage. Verify that it is in good condition and clear of paper bits or other obstructions. NOTE:The star wheel assembly is located inside the printer on the output side of the carriage. The star wheel assembly is a set of small, star-shaped wheels on top and rubber rollers on the bottom. The assembly grips the printed side of the paper, and moves the paper to the output tray after printing.Replace the rear access door and verify that the rollers on the door and the rollers inside the rear access of the product are "matched up" with each other.Press the power button to turn on the product.Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include: Plain paper, 20 to 24 lb (75 to 90 gsm) Legal size paper, 20 to 24 lb (75 to 90 gsm) Card stock, up to a maximum of 110 lb (200 gsm) Envelopes, 20 to 24 lb (75 to 90 gsm) Photo paper, 145 lb (236 gsm) NOTE:Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.Step Four: Make sure that the paper is loaded correctly Gather a stack of plain, white paper and load it in the product's input tray.Use only one type of paper in the stack.Use 10 to 25 sheets of paper in the stack.Fan the stack of paper to make sure that the sheets do not stick together. Tap the stack of paper against a hard, flat surface, such as a table top, to make the edges even.Insert the stack of paper into the input tray.make sure that the stack of paper is flat in the input tray. Verify the right side of the stack of paper touches the right side of the input tray and that the stack is pushed completely into the tray.Position the paper guides firmly against the sides of the paper stack without bending the paper.Step Five: Test the All-in-One Follow these steps to print a self-test page. If the page prints successfully, the product is functioning correctly.Press the Setup button on the printer.Depending on what product you have, perform one of the following:Press the arrow key to select Print Report and then press OK.Press the arrow key to select Self Test eport and press OK.A test page prints.If the test page prints without damaging the paper, you do not need to take any other action.If the test page is damaged during printing, proceed to the next step.NOTE:For printers which do not have a Setup button, check the product documentation to find out how to print a self test page.Step Six: Contact HP If you have completed all the steps listed above and are still experiencing a problem, the rear access door or the star wheel assembly is likely damaged. To replace the rear access door, contact HP. If the star wheel assembly is damaged, replace the product.Cause There are several possible causes: Bits of paper might be obstructing the paper path and need to be cleared.Unsupported paper types and sizes might catch and tear in the printer mechanism while printing.Paper pushed too far into the input tray when it is loaded, might feed into the printer incorrectly, causing the paper to tear.Paper stacks loaded into the input tray with too many or too few sheets of paper, might feed into the printer incorrectly, causing the paper to tear.Paper stacks that are not properly stacked when loaded into the input tray, might feed into the printer incorrectly, causing the paper to tear.The rollers on the rear access door and inside the product's rear access might not be clean, in good condition or freely rolling.the star wheel assembly might be obstructed or have damaged or missing parts, causing the paper to tear.The rear access door might be damaged.The wheels on the star wheel assembly might be damaged.
Oct 12, 2011 | HP Officejet J5780 All-In-One InkJet...
My paper feeds out the back and I want it to print out the front. How can I set this up?
If the paper output tray is pulled out at the bak then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 28, 2011 | OKI Electric Industry B4600 Laser Printer
How do I print envelopes on Office Jet 6500?
  • Flip up the printer's output tray to reveal the input tray below and remove any paper in the input tray. Insert up to five envelopes into the input tray, print-side down, and slide the width guide so it touches the edges of the envelopes but does not bend them.
  • 2
    Fold the output tray back down and flip out the extension piece at the end of the tray. Fold up the paper stop at the end of the output tray's extension to keep the envelopes from falling out of the output tray.
  • 3
    Click "File" at the top of the software program you are using to create the text to be printed on the envelopes. Click the "Properties" or "Setup" button in the window that opens, then click on the tab labeled "Paper/Features."
  • 4
    Click the "Type Is" pull-down menu and select "Envelopes." Select the "Size Is" drop-down menu and click on the size of the envelopes you have loaded in the input tray. If you do not find the correct size, click "Custom" and type the height and width in the window that opens, then click "Save."
  • 5
    Click the "Source Is" drop-down menu and select "Tray 1." Click the "OK" button at the bottom of the window to save your settings, then click the "Print" button to begin the print job.
  • Read more: How to Print Envelopes With the HP 6500 E709A ' eHow.com http://www.ehow.com/how_7439186_print-envelopes-hp-6500-e709a.html#ixzz18tq0C0JF
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 23, 2010 | HP Office Equipment & Supplies
    What does e073 0003 error mean on canon 1180.
    E, 0, 7
    FINE Cartridge is not installed in the correct position
    E, 0, 3
    Paper Output Tray is closed / Paper jam
    Summary
    If the Paper Output Tray is closed, open it. The machine resumes printing.
    If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
    E, 0, 3
    Summary
    Techbelkin please rate me
    Nov 03, 2010 | Office Equipment & Supplies
    Error e03, but there is no jammed paper
    E, 0, 3
    Summary
    E, 0, 3
    Summary
    E, 0, 3
    Summary
    Techbelkin
    Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Not printing black
    To align the printer from the control panel
    1. Load letter, A4, or legal unused plain white paper into the input tray.
    2. Press Setup.
    The Setup menu appears.
    3. Press to highlight Tools, and press OK.
    The Tools menu appears.
    4. Press to highlight Align Printer, and press OK.
    5. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
    Recycle or discard the page.
    A success or failure message appears.
    Note If you have colored paper loaded in the input tray when you align the printer, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or ink
    cartridge.
    6. Press OK to continue.
    7. Recycle or discard the page.
    Oct 13, 2009 | HP Photosmart C7280 Laser Printer
    Hp printers continue to jam
    Print a self-test report Use the following steps to print a self-test report.
    1. Load plain white paper in the input tray.
    2. Press Setup , and then press 2 . The Print Report menu displays.
    3. Press 1 to select and print a Self-Test Report .
    IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
    Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
    I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
    Mar 19, 2009 | Canon Office Equipment & Supplies
    Ricoh CL3100N
    Have you setup for double-sided printing?
    Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
    44 people viewed this question
    Ben Johnson
