Question about Sony STR-DE945 Receiver
I have a sony receiver str-de945 and i have a clicking sound and it only pleys in 2 channel stereo.
I cant change soundfield modes or touch anything else or the sond i have will go out and it will just hiss.
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
SOURCE: Stuck!
I was able to fix this issue by opening up the receiver, removing the circuit board that the power button and speaker selector knob contact, and then reseating that board back onto the circuit board it was connected to (the one with the majority of the control buttons).  This completely resolved the problem.  The power button works again and the audio does not drop out anymore.
Posted on May 16, 2008
urnotjoeking
  • 5 Answers
SOURCE: StR-DE945 stuck in auto protect mode
I had a mechanical problem with the relay on the 1st power supply board. The relay right next to the small transformer. The blac cover for the relay just comes right off. Make sure that the little black plastic piece is still in position (you'll see what I mean when you open it.) and check the contacts on the relay.
Posted on Jan 24, 2009
  • 92 Answers
SOURCE: goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
Posted on May 20, 2009
SOURCE: Sony STR-DE875 receiver has no sound from right
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Posted on Oct 26, 2012
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Can I get digital output through my STR-DE945,
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE945-Receivers-manual/id/387dj982/t/2/
The far left optical connector on the back is an output.
Feb 21, 2011 | Sony STR-DE945 Receiver
My str de 945 will not power up when i hit the power button
Most often that is caused by a failure in the power supply or one output channel. Try disconnecting all the speakers and see if it will power up (relay click) without them. If it does they you have poor connections at the back or the receiver or the speakers. Possibly a failed speaker. If the unit powers up then add one speaker back at a time and repeat the start up. Make sure that no bare wires are touching each other anywhere. If that doesn't solve the problem or if it won't start up with no speakers then it's a trip to the repair shop time.
Aug 24, 2010 | Sony STR-DE945 Receiver
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Sep 14, 2007 | Sony STR-D865
Stuck!
Aug 18, 2007 | Sony STR-DE945 Receiver
No Center Sound
it probably isn`t :) it should be a problem with the settings :) i have a str de335 too and i get decent sound.. it depends on what type of source of input u`re using . try this.. hook up a stereo source. go into setup mode.. select wide or normal setting for center, then activate sound field .. c-studio for example.. if the sound is annoying something is wrong with the amp.. :-s btw use the delay settings from 1-6 6 if they are close together :) . When using 5.1 input... turn off soundfield always.. and triple check center settings&levels
Mar 22, 2007 | Sony STR-DE335 Receiver
Jan 07, 2007 | Sony STR-DE945 Receiver
Sony STR-DE945 Receiver Logo
37 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
