Question about Canon MF3110 All-In-One Laser Printer
Scanner or Copy not working
I am facing problem in Scanning and copy. When ever i give command of scanning any thing its give me lines as well in copy, and this thing not only via software but also if i wanna do same thing in printer i face same problem in copy its give me lines. Kindly help me regarding this problem what shell i do, thanks
  • joel_ou Nov 24, 2008
    same problem. these annoying vertical lines get printed on everything now. i noticed it when i first installed vista. is it a compatibility problem?
  • 62 Answers
Replace the toner crtridge
Posted on Jun 10, 2007
SOURCE:
What are the commands to initialize scanning lamp or unit or what unit or part is faulty due to which not copying instead giving blank paper.
Make sure the document you are trying to copy is face down on the glass. This and more should be explained in the owners manual.
Feb 27, 2016 | Office Equipment & Supplies
I get a black line when scanning, ( not when printing)how do i fix it
This is commonly caused by a mark on the scanner plate. If you place your document to scan on the scanner plate (Lift the lid and place it on the glass plate) and scan or copy the document does it come out clean? If you feed the document through the Auto Document Feeder doe the line appear?
If when place on the plate it is clean but fed through the ADF there is a line, then when you lift the lid on the scanner you will see a narrow glass plate at the end (Normally the left end) of the scanner plate. Give this glass a clean and your mark will go away.
If the scan or copy is lined when using the Flatbed scanner and the ADF then the problem will be in the scanner lamp which will be probably uneconomical to fix.
Oct 09, 2014 | Brother MFC 6490CW InkJet Printer
System error e000
Are you getting the error on your computer or on the printer display?
Jul 27, 2013 | Canon imageCLASS MF4320D
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Why does lines appear in my printed copy?
If you're getting lines, especially when making copies or scanning, it could be due to some dirt on the scanner glass. Wipe your scanner glass with a lint free cloth. Then try scan or make a copy again to verify that the problem is fixed.
Mar 04, 2012 | Lexmark X1150 All-In-One InkJet Printer
Face up or face down for faxing?
Hi
If you are using the feeder in the top. The document you want to scan or copy should face up.
But if you are using the glass for copying or scanning, it should be face down.
Regards
Mar 11, 2011 | Canon PIXMA MX310 All-In-One Printer
How to scan into my computer
Hello, I am happy to help you with your question. Samsung SCX-4200 supplies software calls Samsung Smarthru. This software application includes a scan command. The software is locagted on the CD that accompanied the printer.
Here are some excerpts from the manual:
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
Dec 22, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Network scanning problem
scanning from any device is simple you need three things
   user name   bill    password    piguine    path            \\server\scans\shared folder
the scanner needs rights to write to  a folder on the network..  good luck
Apr 27, 2009 | Samsung Office Equipment & Supplies
Canon MF3110 All-In-One Laser Printer Logo
280 people viewed this question
Clive
Clive
old marine
old marine
