How do I swap out my broken ethernet RJ-11 connector/port on my Dell optiplex 330
  • 2,878 Answers
Leave as is if the port is part of the motherboard. Instead pick up an add-on card. Easy and cheap fix.
Posted on Nov 29, 2012
  • Erin Loffie Nov 29, 2012
    cheap suggestions? Fry's? Any ole' ethernet card?
5 Suggested Answers
oblivion2k
  • 150 Answers
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
Posted on Feb 27, 2009
  • 65 Answers
SOURCE: in my dell desktop optiplex 330 hard disk is
Is it a BIOS password or a HDD password? If it's sewt in BIOS, you could try to reset the BIOS to factory default (which should remove any BIOS passwords) If however it is a HDD password, it is a bit different.. you may need to restore your sytem (low level, high level formats, then reload your OS sorry but you likely lose all your data..What OS do you use? there are programs that can possibly give you a boot cd depending on whether your system is fat32 or NT.. NT is more complicated because fat32 will not read NT BUT NT will read fat32.. IF you have the ability to restore your OS then first try to do a complete restore with backup.. that way you may be able to save most of your datafiles.. if you have never accessesd the pc then just try a destructive system restore (will low-level, then high-level format the HDD and reinstall your software without any SW passwords..
First thing I would try is to get into the BIOS and unset any passwords there.. If you need more help you can try to contact me mage0213@aol.com with more information
Posted on May 06, 2009
  • 23 Answers
SOURCE: my dell optiplex 330 can not switch on, whan I put
If you are getting an amber light flashing, your power supply is faulty.
If it is a solid amber light, you motherboard is faulty or one of the componants are faulty.
I would suggest giving Dell a call. They would beable to pin point the problem and give you a quote. Some of their componants are non standard and can only be purchased from them.
You could try reseating all your componants on the last resort but it is unlikly to help.
Posted on Jun 26, 2009
Current009
  • 135 Answers
SOURCE: Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
Posted on May 31, 2010
330 power supply
Dell Optiplex 330 Desktop Product Video http://www.youtube.com/watch?v=K3CDVOZMVpo DELL (OPTIPLEX GX520/320/330) http://www.youtube.com/watch?v=xbaDqnoDNP4 Unboxing & Setting up My Dell OptiPlex 330 http://www.youtube.com/watch?v=LX_-y8Y9WcY Dell Optiplex Computer Powersupply issues.MTS http://www.youtube.com/watch?v=dzSCXgvAFGg
Mar 25, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
Were do the jumpers go on a optiplex 330
There is the Password jumper (PSWD), and the CMOS jumper.
The CMOS battery is also termed the RTC battery.
Real Time Clock battery.
The CMOS jumper is labeled as RTCRST.
Real Time Clock ReSeT.
Jumper pin location is confusing if you go with Dell documentation.
http://support.dell.com/support/edocs/systems/op330/en/ug/mtparts.htm#wp1607303
Dell Support documentation shows the RTCRST jumper pins near the Intel chipset, and PSWD jumper pins near the outside edge of the motherboard.
I'm also looking at the Dell Optiplex 330, Technical Guidebook, Inside the Optiplex 330,
http://www.dell.com/downloads/global/products/optix/en/optix_330_techspecs.pdf
Location of RTCRST jumper pins, is near the left corner of the Intel chipset, instead of the right as shown above, and PSWD jumper pins are in the same location.
And several views of Optiplex 330 motherboard's on Ebay,
http://www.ebay.com/itm/Dell-Optiplex-330-Motherboard-Socket-775-KP561-/140870576837?pt=Motherboards&hash=item20cc8a6ac5
(Nice to have that Zoom in feature on Ebay now)
Jumper pins close to the white SATA 2 connector, are the RTCRST jumper pins.
Jumper pins at the bottom side of the Intel chipset are the PSWD jumper pins.
Jumper cap stays on PSWD jumper pins.
No jumper cap on the RTCRST jumper pins.
http://en.community.dell.com/support-forums/desktop/f/3514/p/18683374/18806360.aspx
Regards,
joecoolvette
Oct 23, 2012 | Intel Motherboard
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
I want to connect a CAT5e Ethernet cable (with or without a RJ45 connector) from a DSL router to an older computer that only has a RJ11 input. This will be used for DSL internet service only -- no...
The only "outputs" from a DSL-router are:
* RJ-11 telephone-jack, only if the router also supports voice-over-IP,
* RJ-45 Ethernet port (always present)
You need to purchase an internal network-card, to create an RJ-45 port on the computer, and then use the CAT-5e cable to make the connection.
Feb 20, 2011 | Computers & Internet
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
Does it make a difference if i use a wire splitter? does it make a difference of the order the phone pins are connected in the wire splitter?
What are you doing? Are we talking about telephones (RJ-11) or are we talking about routers and ethernet cable (RJ-45)?????
RJ-11 will fit into a RJ-45 but a RJ-45 will not fit into a RJ-11. Translation, your telephone wire will plug into your router/computer port but your Ethernet wire will not fit into your telephone jack.
If you are working on a telephone, as long as you have dial tone on the other end, it doesn't make a big difference. You should have a polarity checker to insure proper polarity but even if it is wrong, most phones will work most of the time. Get a polarity checker at Radio Shack for about $10.00
If you are working on a router ... well, it is no wonder your network will not work. You cannot split one RJ-45 port into two "Ports" using a telephone RJ-11 splitter. Never, Never, Never, plug your router cable into a telephone jack (RJ-11). Yea, Yea, Yea, I know, I just said a RJ-45 will not fit into a RJ-11 but if you have a telephone cord pluged into the router, guess what, 60 Volts will smoke it. When the phone rings, it rings with 60+ volts and will smoke any computer device it can smoke looking for ground.
If you need more computer ports, get a bigger router or bigger switch or bigger hub or get a wireless router to accomodate your wireless devices.
I hope I have answered your question.
Thanks for your interest in FixYa.com
Feb 13, 2010 | Computers & Internet
Is the ethernet card on dimension 3000 dell alone or part of the motherboard
Since around 1998 all motherboards come with the LAN (network/ethernet) on board.
The port will be at the back of the Dell next to the USB ports, you can't miss it.
Regards.
Nov 09, 2009 | Dell Dimension 3000 PC Desktop
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
Dell Optiplex 330 ADI 1984 Integrated HD Audio
http://www.drivershq.com/Drivers/Dell/OptiPlex/330/11/92/28207/Drivers.aspx
May 02, 2009 | Dell Computers & Internet
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
