Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Black ink will not print
Put full brother carteridges in and cleened heads several times
  • Anonymous Mar 22, 2009
    black ink will not print
Black ink will not print ? help me cliff
Posted on Jan 10, 2009
I have a brother printer DCP-195C but the black ink not functioning. several times i have test prints but black ink doesnt appears. how can i fix it?
try clean the pipes using air compressor but be sure to disconnect the pipes from the print head and clean also print head
Jan 01, 2011 | Office Equipment & Supplies
My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Mar 01, 2010 | Brother DCP 165C Compact Color Inkjet...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
My status monitor says that all my colour supply levels are full. But the printer won't print in colour. Only black & white. Even when I choose the "print in colour" option. This hasn't happened...
Brother Inkjet printers' printheads are very sensitive, using non-genuine ink clots the printhead. Try to clean the head by pressing the ink maintenance button. Sometimes you need to clean several times.
Dec 11, 2009 | Brother MFC-5440CN All-In-One InkJet...
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Aug 22, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
77 people viewed this question
James Cagle
James Cagle
Jim Keysor
