Question about Caroma Home
How to replace outlet washer in bottom of Caroma Duo Set 6-3 cistern
5 Suggested Answers
  • 2841 Answers
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Posted on Jan 09, 2010
bloues
  • 56 Answers
SOURCE: How to replace Caroma toitet suite outlet valve
Hello
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut and plz rate my advice, thanx
Posted on Jul 11, 2010
bloues
  • 56 Answers
SOURCE: I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Posted on Jul 12, 2010
SOURCE: I have a 1998 Caroma Reflections cistern p/n
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Posted on Sep 29, 2010
Caroma duel flush cistern 20 yrs plus not flushing when buttons pushed
well past used by date
parts will be difficult to get so consider a new cistern
Jul 05, 2017 | Caroma Home
Caroma invisi cistern not flushing enough water
check the water level in the cistern
it should be about 3/4 " below the overflow pipe edge
May 25, 2017 | Caroma Home
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universal
toilet replacement parts. I bet you can find one that will fit.
Jan 04, 2013 | Caroma CARAVELLE270ADAW-EL Caravelle...
I have a Caroma Trident cistern which occasionally overflows through the overflow pipe to outside. What washer do i replace?
Have you tried cleaning the inlet valve? It could very well be a small piece of debris stuck in it
Jan 07, 2011 | Home
I have an old Caroma Dual flush ( 15-20 years) and the washers on the inlet valve dont seem to be able to regualate the flow in, after the toilet has been flushed, as a result water sprays up out of the...
Plz rate my advice
Jun 16, 2010 | Caroma 270W-RF Reflection Round Front...
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
I have a 1998 Caroma Reflections cistern p/n 6871774. It is making a hissing noise after the tank is refilled, and water streaks down from the supply rim of the bowl. Which part needs to be replaced?
Jan 10, 2010 | Caroma 270W-RF Reflection Round Front...
Home Logo
459 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
