Question about Kenmore Kitchen Ranges
Maytag accellis 2x MER6750 error F1-1, oven came on by itself
Found that that error means the oven was hotter than 650 degrees. only the top coils were on. How can we fix this ourselves. unplugged stove. Finally cooled off. Plugged back in. burners all work. Oven started preheating, then smoke came from the back of the electronic board area. Unplugged stove again.
  • 7 Answers
SOURCE: F1 and F2
depends on the brand, most of the time its an erc (electronic range control) this can be replaced. find a appliance store near you, give them the model and ask for the price and availability of an erc. If satisfied call a tech. If a tech installs it you have a warranty... get the picture?
Posted on Feb 09, 2008
SOURCE: Maytag Range
F1 on Maytag = Bad touchpad or Clock.
Posted on Mar 22, 2008
  • 185 Answers
SOURCE: Maytag gemini f1-9 error
plug it back in and press the cancel button
Posted on Mar 31, 2008
SOURCE: I have a maytag stove
I have a Maytag stove Model #MER5875QCW The problem is it
Takes for ever for the stove to reach 350c Can anything be done?
Posted on May 24, 2008
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
We have a free standing Frigidaire flat top stove oven that is electric I decided to use the self cleaning feature on it and the bottom element burnt into My husband removed the bottom element before...
I THINK THE HEATING ELEMENT YOU GOT COULD BE WRONG SIZE. I KNOW MINE WENT OUT WHEN COOKING SOMETHING HOTTER THAN I USUALLY USE LIKE 450 DEGREES, IT BURNT OUT. BY CLEANING OUT YOU'RE OVEN, WHICH REQUIRES REAL HOT TEMPERATURES, IT SOUNDS LIKE YOU ON THE RIGHT TRACK. IT BEING OLDER STOVE, A LOWER RATED ELEMENT I WOULD TRY..
Mar 24, 2017 | Kitchen Ranges
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
Oven only heats to 215 degrees will not get any hotter.
Sounds like the heat sensor is bad. I'm assuming this is an electric oven. On the inside back wall of the oven you will see a metal rod sticking out. Unplug the stove, take off the back cover and you'll see where it's attached. Unscrew the keeper and pull it out through the back. Unplug it from the wiring harness.
Apr 15, 2012 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
30 inch Viking ultraline stove, 6 years old. You have 2? burners on the bottom in the oven. One on the right "buffs" or seems to go out then reignites. The "cook" also says it takes...
We inherited a 30 inch Viking Ultraline when we purchased our current house. I was extremely excited to cook on such a high-end range, but this thing has been nothing but trouble. The temperature on the oven is always between 25-75 degrees hotter than indicated on the dial. An oven thermometer is the way I solved that problem. None of the igniters work on the burners (I use a BBQ lighter on all the burners) the broiler has never worked, and one of the hinges broke and required replacement. We actually ordered the hinges off the internet for $25 each and replaced them ourselves--it was not complicated but would have been costly to get a tech out to do it.
After repairing the hinges, I decided to use the self-clean function, which, big surprise, not only did not work, but locked me out of the oven! I tried re-starting the self-clean, breaking the circuit and re-starting it and nothing worked. Having read many posts on the internet, I realized I would probably have to get a tech in to fix it for me. In desperation, I finally turned the oven on to 325 for 20 minutes, hoping it would unlock, and inexplicably, an hour after I turned it off, it unlocked itself. Finally, the burners are impossible to keep clean--no matter what I do to clean them, they always look filthy.
I would never buy another Viking product, as I am totally underwhelmed by the performance of this range.
Apr 21, 2008 | Viking Kitchen Ranges
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
46 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
