Question about Ricoh FAX4700L Plain Paper Laser
Close the cover
DEAR FRIEND: I BOUGHT A FAX,COPIER, 3700l WICH IS FISICALLY SAME THAN 4700L. IT GOES WELL EXEPT FOR WHEN I TURN IT ON, APPEARS A MESSAGE SAYING "CLOSE THE COVER". I DISCOVERED THAT IT HAS TO DO WITH A LITTLE SQUARE "DOOR" AT THE FRONT BOTTOM THAT IT SAYS "A4" THAT DOESN'T THE CONECTION PROPERLY. COULD ANYONE TELL ME WHERE TO BUY THAT LITTLE PART? PREFERIBLE IN MELBOURNE. THANKS CANARIONA
    Genius:
  • 2,985 Answers
You probably will not get a part. But this warning means that a small micro switch near that door is not functioning to say 'door closed'- look for it and make sure it will close properly or has not become dislodges from it mount or loast its wire. You may also seek hel at the Ricoh web site technical support team. Also Take a look at www.fixyourownprinter. com
Posted on Jun 06, 2007
I have a 660 sharp fax . when I 2turn it on its display shows. check cover,check film, check paper. how can I solve it ?
Replace the film, replace the paper(properly installed)and check all covers re-seat them, also check to make sure that the tab that goes into the machine for each cover is not broke if one is then copier thinks that cover is not closed. buy new film.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 12, 2015 | Sharp Office Equipment & Supplies
I get a message "cover open" but all covers are closed
I HAVE SEEN THIS, AND ITS YOUR DOCUMENT FEEDER,WHERE YOU PUT YOUR ORIGINALS PUSH DOWN ON THAT COVER
Aug 29, 2013 | Ricoh Aficio SP C240SF - multifunction ...
Check cover/cart appears. tried changing toner cartridge but message still there. Toner in correctly. is there anything else to check/do?
the message you are getting will show up for both toner and cover. There is a switch that the cover triggers when closed located onder the main unit cover. The tab on the cover goes into a slot located kinda left of center. That switch is infamous for getting stuck or knocked out of place so the tab does not see it. The cartridge is probably good.
Sep 19, 2011 | Canon LaserClass 2050 Plain Paper Fax
Paper has jamed where suppose to come out
to open the copier, on leftsideway is small handle, wich you need to lift up to open copier ( copier opens in right side, by pulling it up ). Remove paper jam, wich is probably in fixing section.
To remove fixing cover remove two screws located in inner side of black plastic cover. Now you will also be able to see if fixing film is damadged, wich can be cause of your problem.
Aug 10, 2010 | Canon PC-950 Black and White Copier
Cant fax, getting a msg "check scan.platform" Thank you, Z
When you remove plastic cover, wich is above paper cass. you will be able to see long black plastic with white scanner section.In the midlle is handle.
You need to open and very vell close it - THIS IS SCANING PLATFORM.
If does not help you have problem with main pcb.
Jun 15, 2010 | Canon L120 Fax Laser Printer
I have an ImageRunner 2016i with the error E000019
the error E019, means that the waste toner is full.
Waste toner is excesive toner, wich is cleand from the drum at copy process, and goes in waste toner "compartment" in drum unit.
To clear the error and clean the waste toner, you need to:
Open front cover, open the left sideway door, by pressing the open button.Then, left from the toner is blue handle wich you need to lower.Then pull out the drum unit.
Then on top of the drum unit, you will be able to see one cork.Remove it and vacume the toner out.
Put back the cork, put the drum unit back in, close front cover, closse left door by pressing them on place where hand is ilustrated.
Turn copier off and on.
These will clear your error.
The instructions for drum unit removal are also illustrated on inner side of front cover, beneath toner replacing procedure.
Hope that helped.
May 26, 2010 | Canon imageRUNNER 2016i All-In-One Laser...
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
My Brother 560 says top cover open when the cover appears closed.
Make sure the covers are completely closed. Open each section an close it making sure it closes with a click. Also check for covers under other covers.
Hope this is of some help.
ED
May 09, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Ricoh Fax 3700L
Fuser error.....Either blown fuse, bad thermistor, or blown lamp. Problem needs to be repaired, and then a WAY over complicated reset procedure has to be performed in service mode to clear the error.
Apr 28, 2009 | Ricoh Office Equipment & Supplies
New cartridge but copier not printing
Did you pull out the orange/red tape?
Check if there is an good connection between cartridge and pin at the right side of crg. inside crg.holder( a little pin wich goes in and out when you open or close cover )
Try with old crg. if it works the problem is new crg.
Sep 06, 2008 | Canon imageCLASS MF4690 Multifunction...
Ricoh FAX4700L Plain Paper Laser Logo
141 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
