Question about Truly Health & Beauty
Truly/Accuread DB61M Blood Pressure Monitor - how to set date and time
I found how to set the date and time on my Truly DB61M blood pressure monitor by trial and error. I suspect other Truly BP monitors do it a similar way. These monitors also seem to go under the name Accuread. It's a pity they don't make manuals readily available online.
Here's how you do it:
1. Put the monitor into the date/time setting mode by holding down the MEMO and AVG buttons together for several seconds, then release.
2. The YEAR will be displayed flashing at the top right of the display. Press the PAGE button to move through the years to the one you want.
3. Press the AVG key to move to the next field, which is the month, flashing on the left. As with the year, used the PAGE button to move through the months to the one you want.
4. Following the same procedure, set the day of the month, the hours and minutes. The monitor knows how many days are in each month, so you can't set eg 31 February.
5. To finish, press the START button (the one on the right with the red marking).
There seem to be some other settings as well as the date/time that come up if you keep pressing the AVG button, but I don't know what they are.
SOURCE: Kitchen aid mixer, voltage issue
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
Posted on Jan 16, 2009
  • 10 Answers
SOURCE: To set the time and date in the Braun Blood Pressure Monitor
call himor her and ask them you going to be late
Posted on Jul 13, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: Kitchen aid mixer makes a sqealing sound. Can
yes it can. just above the rotating head there is 5 screws that can com lose and start rubbing the head as i turns. there is a pin in the the bottom of the spinning head and the only way to get to the screws is to push that pin out and slide it off. there is a few ways to fix the screws from coming out. one is to buy lock washers. these won't allow it to back spin the screws. but you will have to use a file to shave the part of the washers that sticks out. this is the sure way that it won't come out. or you can put lock tite glue to lock them in, but if you need to ever get the screws out again you will break them. before you put the rotating head back on you will need to clean the old grease out because it has metal shavings in it. them replace with a gear grease. just small dabs should do. to much will throw it into the mixing bowl. just put it back together and your good to go.
Posted on Feb 16, 2010
  • 130 Answers
SOURCE: My Kitchen Aid Mixer, Professional 600, model no.
Looking at the diagram here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You will see the motor controller Item Number 19. Looks like a pretty simple taks to remove and replace it. there is also a hall effect sensor Itme Number 24 which monitors the motor speed. That might be faulty as well, but my best bet is the controller.
Unfortunately the parts list does not specify the part number for the controller so a call to Kitchenaid is probably required.
Posted on Mar 30, 2010
How can I set the date and time on my Veridian Smartheart blood pressure cuff?
With the unit off, hold down the set key until the year shows up. Press the mem key to advance by 1, or press the set key to set/accept that value and/or advance to next setting. See: Omron Wrist Blood Pressure Monitor
Aug 26, 2014 | Veridian Healthcare Smartheart Arm Digital...
Tip
on Feb 13, 2014 | Truly Health & Beauty
Truely DB61M
I found how to set the date and time on my Truly DB61M blood pressure monitor by trial and error. Here's how:
Mar 27, 2013 | Truly DB-22 Automatic Blood Pressure...
How do i set the time and date
Setting the date and Time is a 2 step procedure for Omron Hem 609 Blood Pressure Monitor. Check out Page-10 of the below manual for the exact procedure.
http://www.omronhealthcare.com/wp-content/uploads/hem-609n_-_2005_im_eng1.pdf
Aug 23, 2012 | Omron Healthcare Blood Pressure Monitor...
Setting date and time
go to menu
go to settings
go to date and time
and set the time
hope it help
May 10, 2012 | Microlife 3AC1PC Premium Blood Pressure...
What is the m button for
Hope this helps you out
Sep 19, 2011 | Health & Beauty
My blood pressure monitor is reading 20 points higher than my real blood pressure. What can I do to calibrate it to be more exact.
Contact the HoMedic's Consumer Relations Dept @ 800-466-3342 Mon - Fri, 8:30am - 5:00pm ET, they can help you.
Keep in mind, that improper placement of the wrist cuff can cause higher or lower readings, than what they truly are. Also, not keeping your arm at heart level can cause an inaccurate reading.
Mar 01, 2011 | Walgreens By Homedics Automatic Blood...
Jul 07, 2009 | Health & Beauty
Setting Date & Time
With the power off press "Digit". Month is blinking press "Set" for correct month. Next press of "Digit" will give you Day, Hour, and then Minutes.
Mar 18, 2009 | Sunbeam Digital Blood Pressure Monitor
Health & Beauty Logo
51 people viewed this question
Top Truly Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Truly Health and Beauty Expert? Answer questions, earn points and help others
