Question about Sky I Blade Mini IR Helicopter W/ Remote Control
Helicopter spins left and rear rotor does not spin at all
On my first flight I crashed into the sea, don't laugh, wasn't at all funny as I had to dive in to retrieve it. Washed down everything with fresh water, dried it off and tested. Main rotors are fine but after trimming the left spin as far as possible it still spins left. Also the rear rotor does not spin when plugged into its socket on motherboard. Does spin when change to different socket, but spins constently which is not good. Maybe the motherboard is screwed ?????
  • 8,197 Answers
Yes your motherboard shorted out. You need to get a new board or replace the heli.
Posted on Jan 10, 2009
How o fix problem it just keep spinning on the floor
adjust the trim on the controller please watch some beginners videos. In this instance the problem is yaw which is left and right rotation on a helicopter it is affected by the speed of rotation of the tail rotor relative to the speed of main rotor and its gyroscopic effect. the floor cause weird flight effects on helicopters to get the trim precisely set it must be at least 4ft from the ground. but initially just get it to where it is controllable.
Feb 28, 2016 | Protocol Predator SB 3.5-Channel...
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
Helicopter body keeps spinning
add small counter weights on copters plastic body just enough to allow motor to spin without dragging the body and spinning while in flight. check if motor's rotor shaft comes in contact with copter's body, make adjustments on it
Dec 12, 2013 | Toys
One rotor spins when battery is plugged in even if power switch is off.
When the crash happened, was the throttle gimble on the transmitter left at a
throttle up position for any length of time? If it was, it might have burned the
speed control or electronic gyro for the bottom rotor blades. Replacement
of PC Board might be a fix.
Dec 31, 2011 | xheli 9053 Outdoor Volitation Metal...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Hi, the main rotor of my havoc helicopter is spinning in an unbalanced way and causing a high level of vibration making flight impossible
Look on the underside of the rotor. You may be missing one of the small metal weights that balance the rotors.
Jan 08, 2010 | Air Hogs Havoc Heli Helicopters
Problem with the back rotor.
make sure there is no debris such as hair thread or string caught in the back rotor. this will cause it to lock up. Remove it and try fiddling with the trimmer button to help it stop spinning the helicopter
Jan 07, 2009 | Air Hogs Havoc Heli Helicopters
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Sky I Blade Mini IR Helicopter W/ Remote Control Logo
957 people viewed this question
Top Sky Toys Experts
NOEL
NOEL
matt
matt
Are you a Sky Toy Expert? Answer questions, earn points and help others
