Question about Kenmore 96012 / 96014 / 96019 Electric Kitchen Range
Kenmore model number 970-6789 . Hubby is looking for the fuses on my new range. No mention of fuses anywhere. Where are they hiding??
2 Suggested Answers
SOURCE: New Kenmore range model number 790.7230 - front
Replace Dual Heating unit In glass top kenmore 790 electric Range.
Posted on May 29, 2011
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Kenmore Model 790. Burners work but the electronic buttons and the oven do not work. Is there a fuse for this? None of the display works or lights up.
You will need the control board for your range. I can direct you to the part if you can post the model number off the unit. Look in the oven for it.
Aug 03, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kenmore gas range model # 970-331513 oven will not light, no such model number on their webpage. The burners light but not the oven. The igniter glows, there is no smell of gas. Range is new to us. Also,...
I cannot find the model number either, however, if you look on the enclosure into which the control board fits, there will be a label with a number beginning with 316 or 318. If you provide me with that number I will try to help you. I am familiar with these as I work for a company that repairs failed timers.
Mar 30, 2011 | Kenmore 71071 Gas Kitchen Range
Broiler not working. How can I replace the fuses if that is the problem? Kenmore Range bought in 2002. Model C970-595081 Serial NF 2171 0264?
the model number you sent doesn't come up,is it gas or electric?if it's gas most likely it will be an ignitor.if it's electric probably the element.send correct model number off the machine,open the bottom draw,look at the left or right part of the frame and you'll see a tag with the model and serial numbers,just need the model
Mar 06, 2011 | Kenmore Kitchen Ranges
Purchased a kenmore electric range around 1 and 1/2 yr ago ( 790.9437370) and i heard a pop. The heating element appeared that it was burned. My hubby just installed a new one, and again, the oven does...
check the circuit breaker for the house ..the breaker prob. blew ..if not ..unplug range ..remove the back panel to view all them wires an switches ..look at all of the wires an connections for burt or broken wires ..if all looks good ...their may be a thermal fuse located where the switches are .. look real good with a flash light ..you will find the problem ..you may need a volt/ohm meter to test voltage ..or thermal fuse ..let me know an good luck../joe/
Aug 29, 2010 | Kenmore Kitchen Ranges
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore model 95032 - buy new or get repairs?
I would say buy a new one if you can get a replacement for $399.00.
You can get an idea of parts costs by going to SearPartsDirect.com and entering your model number. I would think the element would be about $25.00, and the top would probably be another $150.00. Add in labor, and your quickly over $200.
I would do the same thing if I didn't know how to work on them.
Jan 24, 2009 | Kenmore 95032 / 95034 Electric Kitchen...
New Electronic Oven Control does not work, Kenmore model 7909634
our top elementes work but the oven and the display don't . All fuses are good and nothing looks burnt. Some smoke came from inside the oven but the elements look good.What's wrong?
Jan 21, 2009 | Kenmore 36665 / 36669 Gas Kitchen Range
Kenmore 96012 / 96014 / 96019 Electric Kitchen Range Logo
57 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
