Question about Garden
My echo cs-670 won't start - Garden
3 Suggested Answers
  • 4088 Answers
SOURCE: CS-670 . Cleaned fuel tank , lines , carb. New
Check for blue, snappy spark at the plug (gapped at 0.020"). If weak or nothing, remove the flywheel cover to expose the ignition module. Check the module gap with a thin business card--turn the flywheel magnets under the module poles, insert the card into the gap, loosen the module screws, and allow the module to contact the magnets, then tighten the screws. Turn the flywheel somewhat to remove the card. Recheck for spark--if ok, try for engine start. If still no spark, remove the ignition switch wire from the module and retry for spark. If still nothing, replace the module. Install per the above instructions. Hope this helps!
Posted on Jul 16, 2010
  • 2239 Answers
SOURCE: I have an Echo CS-3450 16" Chain saw that starts
This is classic fuel starvation, it needs to run a little rich when free running, when it goes under load it needs the extra fuel to keep it going, if you have replaced the fuel filter, and the fuel hoses are good ( no leaks, or cracks in the pipe, give the pipe a tug to see if fuel squirts out ) then there is dirt in the main fuel screen under the pump diaphram, remove the carb, remove the alloy pump cover, normally held with a single screw, under here will be a gasket, and a pump diaphram, in that order, pressed into the carb is a very fine screen, this should be replaced, or at least cleaned, check the condition of the diaphram, this should be supple not hardened, rebuild and try again, the H screw on the side of the carb controls fuel to the main jet, if need be increase ( screw out ) 1/4 turn.Somewhere from the tank will be a breather, this allows air into the tank to stop a vacume occuring, to check this slacken the filer cap when the machine starts to die, if it picks up again it is a breather issue.
Posted on Jul 18, 2011
Need a manual for above
echo air filters do not have a manual nor fuel specs.
Mar 28, 2016 | Echo Air Filter for CS-440, CS-450,...
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
I have a PB251 Echo blower that won't start. I have a good spark Good compression and clean new gas is getting to cylinder because i have a wet spark plug when i removed it ,yet it won't even...
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
Aug 31, 2011 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Jul 06, 2010 | Echo Garden
Pull start and pawls with back plate for echo 602L
I think what you seek is listed here: http://www.echo-usa.com/documentation.asp?Model=CS-602VL&lang=E
See the "Starter and Magneto" print.
EchoUSA (all models)
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 28, 2010 | Echo Garden
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
56 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
