Question about Makita Saws
Remove helical gear 2703 table saw - Makita Saws
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
miket756
  • 2702 Answers
SOURCE: MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Posted on Mar 28, 2010
  • 8 Answers
SOURCE: I broke the rip fence clamping handle on my makita table saw 2703
you can just order a new handle for it
Posted on Aug 18, 2010
Fiero_GTV6
SOURCE: I have a makita 2703
Actually, it's part #74 in the diagram. Part #75 is one of the 2 brush holder covers that each screws out to access and remove each brush.
Posted on Jun 06, 2012
How do I adjust the rip fence on a 2703 table saw
Goto this link:
http://powertool.manualsonline.com/manuals/mfg/makita/2703.html
The instructions for adjusting the rip fence are on page 11
Feb 16, 2011 | Makita Garden
What is the most efficient way to remove and replace the switch on the Makita 2703?
there is only one way that I know of. Unplug tool and lay on its backside to expose the undercarriage of tool, remove the screws holding the switch plate on and remove box
Aug 24, 2010 | Makita 2703 10" Table Saw, Electric Brake
Switch wiring for makita cut off saw
go to makita.com enter yr model # in the search bar, down load a parts breakdown, it should b there
Aug 07, 2010 | Makita 2703 10" Table Saw, Electric Brake
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
My makita 2703 blade movement quirks
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_2703.pdf
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/2703.pdf
Here are two links for the parts manual and the owners manual. It is not uncommon for a tool to go slightly out of line with use due to vibration and and movement of the arbor. As for the tool not tilting, it just sounds like the worm screw and gear are off line. this is a pretty quick fix but it requires you to turn your saw upside down to access the set screws. I glanced at the diagram and it looks like the handle for the adjustment is held on by a set pin. you will also be able to access this from inside the cabinet.
Feb 24, 2010 | Makita 2703 10" Table Saw, Electric Brake
Table is "humped" 1/16" in middle of table. How can i level my table back down?
Is it the table or the insert that is humped. I have never heard of a table especially in the middle being humped. I would recommend that you call 1-800-4625482 that is the Makita Tech Support line and see what they can come up with versus replacing the table
Jul 31, 2009 | Makita 2703 10" Table Saw, Electric Brake
How to set fence square to blade
dfowl:
Try this first:
http://www.makita.com/en-us/Assets/images/Products/2703X1/owners_manuals/2703.pdf
Jan 27, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
32 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
