Error Message 'F:\ setup.exe is not a valid win32 application'
I have recently installed a LITE ON DVDRW SHM 16P65 and for the most part it works well, except that when I atempt to load software from a DVD ROM I the get the error message F:\setup.exe is not a valid win32 application. I have downloaded the latest firmware from Lite on. It will load software from a CD rom and play DVD's, CD's and even burn CD's (I haven't tried to burn a DVD yet)etc. It is connected as the slave. Any suggestions? I get the same when I try to install a program, But I can review what on the dvd, no problem. John
    Problem Solver:
  • 5 Answers
What my mother always said was Ghosts? More than likely your problem? Should be the disk that came with the Lite-on was a 16 bit app.The pc in the registry is more than likely set to 32 bit app. Easy is to make yourself a copy of the download from lite on for the updated driver.If you deleted go back to them and download another. Copy it to disk, put in the cd,or dvd rom to check thats what you have!
Now that you have it, go to control panel remove the disk you first installed that came with your lite on!
Also remove it from the trash container on your homepage. Shutdown and restart PC. Now see what
Did? If the errors gone If the litedoes everything it is programed to? Your the man! If not, then we go back to control panel and remove the other driver you downloaded from liteon? Go to the homepage and take out the trash.Shutdown and reboot? Then after she restarts and all the startup programs are loaded? We install the one you have on the disk.Open the control panel,set up to install program?
Put in the disk with the program liteons Driver disk. After the liteon drivers installed. Go to the shutdown
and restart PC. After windows loaded all is idle, then you test the liteon drive.No errors ,is the thing
we are searching for.OK shoot me an email to say you're the man !You fixed it? Good luck!
Posted on Jan 10, 2009
Setup.exe is not a valid win22 application
You may see Windows error code 193 (%1 is not a valid Win32 application. (Code 193)) when you are starting a Windows Share Point server or a Windows Exchange server. The error message will also generate general Service Control Manager messages in your system logs, too. Error code 193
Aug 27, 2012 | Remington Rem Mod 715 308 Win 22
Win32 application not vaild
The application is not supported by the win32 system file of your windows XP
Aug 21, 2009 | Microsoft Windows XP Professional for PC
I uninstalled nitro. nitro for some reason blocks dvd roms from loading, and give a win 32 mesg.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Mar 18, 2009 | Computers & Internet
Skype installation
send me your email address so that i can send you a good skype messanger setup @ flexydov@gmail.com
Jan 21, 2009 | Skype IM
D:\setup.exe is not a valid win32 application
I don't the problem in the drive, please try to copy the file to your desktop then run it again the same error appears, download the installer for your windows then try from the CD
Dec 04, 2008 | Microsoft Windows XP Professional With...
Windows xp error
so you can run a windows cd but cant run other apps?
Nov 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
