Question about Dell ST2410 Monitor
Dell st2410b monitor won't stay lit
The power light stays on...but the screen is black. If the power is turned off and then back on, the screen appears for about 2 seconds and then goes back again
  • 36 Answers
SOURCE: monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Posted on Jul 12, 2008
Benimur
  • 6966 Answers
SOURCE: Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
  • 19 Answers
SOURCE: Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Posted on May 16, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 1684 Answers
SOURCE: Dell E173FPc monitor worked fine yesterday.
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 31, 2009
Testimonial: "Excellent site"
What is the difference between Dell st2410 and Dell st2410b
Anonymous,
ST2410 has a white back bezel. ST2410B has a black back bezel. Otherwise, identical. So the (B) stands for black.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Oct 15, 2014 | Dell Computers & Internet
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
HP LE1901W won't stay lit up
usually with lcds, this can be caused by a bad inverter or power supply
Jun 20, 2012 | HP L1710 LCD Monitor
My Compaq 172 monitor won't stay on but for maybe 30 seconds then goes blank. When it does this, the on/off button is still lit up, but I have to lush it manually to get it back on for about another...
Failing Power capacitors. The capacitors hold the charge necessary to build up the voltage that lights the screen. When they leak or fail to hold the charge, the screen will cut out. It could also be a fault in the switch circuitry. Really needs looking at by a qualified technician.
Jul 21, 2011 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Monitor went black and now stays black after
pdshapiro, Learn flashlight test in my fixya profile to determine current state of shutdown of units "switch-mode-power-supply"... Then do more reading and visit some of the web links mentioned in my many responses to other owners of Black or Blank n Black screen monitors. You will find out all you need to know and all options if you read my older (late 09 posts) responses to other owners of same or similar sympton ccfl back-lit lcd monitors. JUST DO SOME READING FIRST. Then come back to this post and give it a rating if it steered you in the right direction. Bye for now. 12fixlouie
Mar 27, 2010 | Dell UltraSharp 1504FP Monitor
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell ST2410 Monitor Logo
654 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
