Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All pro 200t
Please help,i have all pro heater was working fine today switched it off for 5 minutes when i went to start it again,nothing switch light comes on but thats it,checked fuse its fine.any help would be greatly appreciated..
  • john84cam Jan 11, 2009
    i took out the ignitor,the element seems to be gone off it,would this stop the motor from starting up?iam living in ireland,would i have to get parts sent from america.
    thank you for youe help
  • Anonymous Jan 30, 2009
    i have a200t i put in a new ignitor is the ignitor supost to turn red all i can get is raw fule
  • 61 Answers
It may be a reset switch on the heater. Usually located near where the electric supply goes into the unit.
Posted on Jan 10, 2009
2004 Alero wont start!
sound like theft security problem.when you try ten minutes did you leave ignition switch on position for ten minutes until the security light turn off then turn off ignition switch for 5 seconds then try starting vechicle.when you do 10 minute trick security light has to turn off or disappear when you see security light go off turn off switch 5 seconds then try starting vechicle.
May 22, 2013 | 2004 Oldsmobile Alero
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The clean light blinks in a pattern of 7 times then off for a second and then 7 times again. The machine won't start any new program. If you press cancel nothing happens.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Feb 16, 2011 | Dishwashers
I drove to work this morning, 18 miles from home. When I was parking backwards, I saw the battery light on the dashboard went on, then the ABS light went on too. I was able to park properly then switched...
You need to go straight to the shop, the battery light is on because your alternator is not charging the truck will only run until battery drains again, the brakes have nothing to do with it,hope the shop is not far away the battery will build itself up enough to start and run a few miles try not to use heater, radio or lights so you will make it, the only other thing that may have happened is the belt broke, but i think its the alternator, good luck hope this is helpful.
Oct 27, 2010 | 1996 Ford Explorer
Sometimes the dryer starts and sometimes it does not. When it does not I press the push to start and nothing happens but then 5 minutes later if I try it will work fine. Sometimes I have do try this a...
This sounds like it could be an intermittent door switch problem, or a loose connection. the next time it does not want to start up, try pushing the door closed and hold it in. If it starts, then it is the door switch just not quite clicking. Try it and let me know. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try to get you fixed up.
Jan 08, 2010 | Kenmore Dryers
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
200T would burn
During start up, a hot surface ignitor glows brightley to ignite kerosene, check to see if it is broken
Nov 08, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
269 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
