Question about JVC Kd-r810
Battery disconneced now jvc kd-r810 car stereo will not work
SOURCE: cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Posted on Jan 18, 2009
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
  • 13 Answers
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Posted on Apr 22, 2009
josetejas
  • 300 Answers
SOURCE: how do you set the clock on a JVC KD-R200 car
Press and hold SEL button until the menu appears
Using the scan (FWD/REV) button, select Clock H
Using the volume knob, set the value
Using the scan (FWD/REV) button, select Clock M
Press SEL to save and return.
Posted on Jan 22, 2010
  • 132 Answers
SOURCE: how do you set the clock on the kd-g120r jvc car
Turn the tuner on then push and hold the SEL button which is at bottom left of radio and then turn knob until CLOCK is displayed.
Posted on Apr 04, 2010
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
Jvc how to install
Replace it with the original Stereo system its simple. connectivity is the same from back.
Jul 11, 2014 | JVC Kd-r810
JVC KD-R810 power wont stay on
If it was working early, then it is failed. It needs to be serviced.
If it never worked since you installed, then check wiring.
Feb 08, 2012 | JVC Kd-r810
I need a user manual for the JVC KD-R810 car receiver
is it possible to download a free owners manual for my jvc
vhs and cd recorder model no HRXVC26U ?
mistyharb@aol.com
Aug 04, 2011 | JVC Kd-r810
I have recently bought a car that has a jvc kd-r601 stereo and I have disconnected battery and now it wont work, any ideas?
Reconnecting the battery causes a surge which can pop fuse. Generally there will be a fuse panel under the hood and underneath or on the side of a dash. There is also a fuse on the back of the stereo
May 14, 2010 | JVC KD-R600 Car CD/ MP3 Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
JVC Kd-r810 Logo
76 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
